Cant shift to 4 Low
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Dandwg, Jul 24, 2003.
  1. Dandwg
    Dandwg 1/2 ton status
    Feb 9, 2003
    190
    Turlock, California
    Hello all,
    I am having a problem shifting to 4 Low. We went wheeling a while back, and while I was on a steep hill (parked) I went to go in reverse ande when I did, I heard a load CLANK sound. Sooon after that I tried shifting my transfer case down to 4 lo, but I could not force it to go all the way down. I removed my front driveline when I got home (it was practically bent) Even without the front DL I still could not force it down to 4 low.
    I am not sure what the problem is. My thinking is that it is either one of these:
    1: Trrnasfer case fried up, melted the gears inside.
    2: Body lift shifted not letting my shifter move freely.
    3: I might need to disconnect shifter and reset set it beccuase it skipped a gear from forcing it down.
    4: I need to eat my wheaties and force it with a BFH /forums/images/graemlins/smile.gif
    ANy more ideas will be gladly appreciated. I could take some pics if any visualls needed, thank you all in advance.
    /forums/images/graemlins/k5.gif
  2. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    SInce you said you had a body lift, I'd look to see if it's hitting due to that. Have someone try to shift into 4lo while you are under lloking at where the shifter goes through the body. I'd check that first.
    Good Luck!!
    /forums/images/graemlins/burb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    Good Luck!!
    ive had that problem... put a 3" body lift on.. put truck into 4h or 4l .. one all the way forward and the other all the way back... had to slam it in.. cuz the shifter hit the metal... then sometimes.. flexin the cab would bump it out of range.... GRRRRRRRRRRRRR /forums/images/graemlins/thinking.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sawzall fixed that on my truck.
