can't stop the clunk....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fjleiter, Apr 20, 2004.
  1. fjleiter
    fjleiter 1/2 ton status
    Feb 13, 2004
    278
    Palmyra, NY
    can\'t stop the clunk....
    have a 90' blazer that clunks when put into gear or when shifting between gears (automatic). Figured it was probably the U-joints so replaced them today. problem is.. it still clunks.. Seems a lot better when accelerating etc.. but still clunks when put into drive or when coasting and it downshifts. When you put it into drive it clunks and lurches like it has a high idle but idle is right where it should be (does it regardless of engine being warm or cold). What else would cause this?
  2. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Re: can\'t stop the clunk....
    Mine does that too. I dont know if its just my 700r4, or my detroit. /forums/images/graemlins/dunno.gif
    -Harrison
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Have you checked the U-bolts and the tranny mounts?
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Mine does it too, typical truck clunk, i believe it has something to do with being an older truck, with wear on the trans, transfer case and rear diff, all combined, creates slop all as one, which makes a "clunk"
  5. fjleiter
    Feb 13, 2004
    278
    Palmyra, NY
    Was my next step, still trying to find out what the bolt size is for the drain and fill bolts on the x-fer case so I can do it all at once.
  6. fjleiter
    Feb 13, 2004
    278
    Palmyra, NY
    Kind of what I figured but it still drives me nuts (I'm a little anal retentive about errant noises on my vehicles. Always hear the little noises no one else ever hears...)
    Should just listen to my buddy who says "turn the stereo up, the windows down and you'll never notice it" (scary thing is that he's a master mechanic, of course he's the same a**hole who convinced me to buy this K5)
  7. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    They're 1/2" NPT. Pipe threads.
  8. 4xcrazy
    Oct 31, 2003
    9,471
    5
    BTW, it'll be on it's way tomorrow. sorry for the delay. been busy during the days.
  9. motofool
    motofool 1/2 ton status
    Apr 7, 2004
    361
    DFW tx
    mine clunks in teh driveshaft where the slip yoke is threads are worn check your i also have a bit of play in my gears up front
