cant turn those big wheels, steering squeeks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mike83blazer, Nov 16, 2002.
  1. mike83blazer
    mike83blazer Registered Member
    Nov 16, 2002
    90
    Southern California
    When I turn my fron tires i get a loud noise from the steering box i think. I have power steering( or had).
    I have 83 blazer , any idea? it has plenty of fluid and it seems to flow. please help.
    This is my truck. http://www.pless.net/blazer.htm
    Mike Pless
  2. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    If it's a squeek, or squeel, then your power steering pump belt is loose. When we throw these big tires on it puts a much larger force on the box then it was stock. Once the belt is tight then you can do these mods http://westtexasoffroad.homestead.com/powersteering.html I did these and I can turn the wheels a 100 times easier then before. Depending on what size tire you have you might want to think about getting a frame brace, especially after doing the mods, and if you plan to wheel it hard. You can find those at www.offroaddesign.com Hope this helps. Later
