cant use factor hitch with...
Discussion in 'The Garage' started by shaun, Feb 27, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    I cant use the factory hitch (1990 jimmy) with the ord shackle flip. The flip covers the farthest foward bolt hole. Any one else have this problem???? What do I do???
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Mine had shiims under the htich to level it out. Turns out that the shim and the flip where the same thickness so I just drilled a new hole in the flip. Maybe you can do the same. /forums/images/graemlins/dunno.gif
  3. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I did the same thing. As much as I hated to do it, I drilled the hole thru the bottom of the flip. /forums/images/graemlins/hack.gif
    I doubt I will ever sell them again and even if I did. The hole is on the bottom and does not effect performance /forums/images/graemlins/waytogo.gif
  4. shaun
    Apr 22, 2003
    745
    I guess I will get some shims and start drilling. Thanks /forums/images/graemlins/waytogo.gif
