Car alarm gurus..
Discussion in 'Audio' started by 88K5Jimmy, Feb 5, 2007.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Can anybody here get the programming directions for the Hornet model 554T/564T? I can only get it programmed by a licensed installer and I want to be able to pick and choose which options I want to have on it....the only shop in town isn't helpful at all.
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,852
    280
    Truckee, CA
    are teh install instructinos online? Normally its just dip switch settings under the cover.
  3. lak2004
    lak2004 1/2 ton status
    Aug 31, 2006
    3,809
    Durango, CO
    go on Directed Electronics website and they should have the installation manual available and owners manual. What exactly is that? Remote Start/Keyless/Security??
  4. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    It's a remote start/alarm/with the 2way key fob...if you're close enough the key fob will alert you to somebody messing with it. However, it went off one time and ran for about three hours before I knew the alarm had been activated. I think the sensor is too sensitive, plus it should cut off after a certain amount of time...or so I would think. Also, per the owner instructions there is a certain button that you push to remote start, however after I got it programmed this button wasn't used to remote start it. Little things like that make me want to the programming instructions, so I can hopefully use certain features but turn certain features off as well.
    Directed's website has owners guides for it but not an installation guide.
  5. lak2004
    Aug 31, 2006
    3,809
    Durango, CO
    I will search around at work for an install manual but I doubt that I have one. But I will check and let you know.
  6. cfurtick
    cfurtick Registered Member
    Apr 14, 2004
    48
    Anderson, SC
    I have access to ALL the DEI manuals. Let me know exactly what you need and I can send it to you. One thing to keep in mind is that if whoever installed your system used a "bitwriter" to program it then only a bitwriter can access the programming. A bitwriter is a small computer type tool that plugs into the brain of the security system and allows you to program the features you want without having to hold the valet and wait for a specified number of light flashes.
    Let me know what you need and I will help.
    Chris
  7. cfurtick
    Apr 14, 2004
    48
    Anderson, SC
    PS
    I just checked the manuals:
    Tha owners manual is 1.04 MB pdf
    The install manual is 1.4 MB pdf
    Let me know if I can help
    Chris
  8. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
