Car Audio Question
Discussion in 'The Lounge' started by Resurrection_Joe, Dec 1, 2006.
  1. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    My bro has a problem with his system
    When he turns up his deck to a certain level, it cuts out and loses power, turning off
    Any ideas?
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Is he using amps? How long before it goes out, like instantly, or will it play load for a while and then shut off?
    I would first suspect poor grounds and/or feed wire/connections for power to the deck, if no amps are in the system, or to the amps if amps are used.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    When I first got into the "big" car stereo systems I had a amp that was only 2 ohm stable and wired my subs down to 1 ohm. That caused the amp too shut down (go into protection) when I turned it up. Not saying that’s your buddy’s problem, but something too be aware of. Now I buy amps that are at least 1 ohm stable. Would like too be ¼ ohm stable, but 1 ohm stable works fine for my needs.
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    What shuts off? The sound? The head unit? The amps? When "it" shuts off, do any of its lights stay on? Does it come back on by itself.Is the head unit pwering any speakers or just sending a signal to the amps. It could be anything from a loose connection, to a bad ground, to a too small of power/ground wire. More details please.
  5. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Just the deck goes off, apparently. We just put a nice amp and two 12" subs in, but it was doing the same thing before the amp and sub install, so I can rule that out.
    The deck goes off, completely, the signal just doesn't stop.
    He ran a new ground straight to the battery....
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Maybe just new head unit time , or if still new enough , send it back . Or sell it on Ebay as parts only radio .
    Its either head unit internally , or external wiring .
  7. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I'll take it out and wire it back in properly. See if that helps.
  8. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    If the head unit lights are going out and the sound is still coming through, I would assume you have a detachable face or a flip face radio. Common problem, but probably not one that you can fix yourself. If it is a detach/flip and it has contacts between the face and the radio you can try cleaning them with a pencil eraser. On a detach face sometimes a little piece of paper wedged in between the two can make the contact better.
  9. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    The whole head unit loses power and has to be turned back on
