Car Show! Dial-up, just go lay down and cry.
Discussion in 'The Lounge' started by TSGB, Aug 20, 2006.
  1. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    Yeah, I got there late, but still got some decent shots. I guess your usual Mustangs and Camaros had already gone, which was kind of convenient! :D
    Cute little Fiat.
    Old "Doc" let me sit on this beast. Said he used to give free breast exams daily.
    The Fumesmobile!
    I liked the lines.
    This is the diesel dragster that my college's diesel program works on. Runs 10.3 1/4's. My roommate is friends with the head of the program.
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    That dragster is cool. It looks like it has air disk brakes. There is two old trucks at work that have the same motor in them supercharged/turbocharged Detroit's.
    I like the 40' Ford the best.
  3. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Love that detroit dragster. Is that an 8V71? What kind of turbos are those?
  4. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I thought nitrous was for gas and propane for diesel? Funny haha?
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    nope nitrous is well suited for diesels
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    no nitrous is for both, you just got confused. Propane helps burn what fuel is there, it acts as a catalyst to burn the diesel fuel. Nitrous adds more oxygen to the mixture. Complete diesel fuel combustion + More oxygen + Twin Turbos = POWER... Though I'd expect a bit more out of the thing. Should have gotten a V12, loose the blower and go Quad Turbo :bow:
  7. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    No can lose the blower. It's a two stroke motor and the blower is used to evacuate spent air when the piston is at the bottom of the stroke. You could not even get the engine started. The exhaust would not exit the cylinders properly. (exhaust would even come out the ports, too... if the engine even fired at all.) You need a source of positive airflow at starting, idle, and running, up to the point the turbo(s) can provide sufficient boost to run.
    Some of the later two stroke 12V and 16V710s (which is 710 cubic inches per cylinder) didn't have a blower but used geared turbos that would produce positive pressure at startup and disengaged to work as a normal turbo after the engine was running.
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [​IMG] That just gets the heart pumpin' now doesn't it ?!!!!!
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    seen V12s minus the blower...
