Carb and Intake install
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DUKE, Feb 21, 2003.
  1. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    New preformer intake and Rodchester Quadrajet, to put on my 350. It looks and seems pretty sraight forward, but I have never done it before. Any pit falls, or common mistakes I should look out for? Any estamate on time? I would guess a day should be suffecient. Anyhelp would be cool. thanks /forums/images/graemlins/thumb.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    put RTV sealant where the heads meet the block at the ends. Oil leaks are common in these areas so when you remove and replace the intake you should really goop it up. Make sure all your gaskets are sitting right, intake and oil leaks aren't any fun.
  3. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    Make sure you are at top dead center one #1 cylinder compression stroke. It makes it easier/quicker to set initial timing on the engine to get it running again.
    And retorque down your intake bolts after a few heat cycles.
  4. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Good idea on getting it it the TDC #1 position, will make it easier to put the distrubutor back in, to get it there, just pull the cap of the dist and bump the engine untill the rotor is on the position where the #1 spark plug wire would be. mark the housing in that spot to you know how its supposed to go when you put it back in /forums/images/graemlins/smile.gif
