Carb Change Over
Discussion in 'The Garage' started by Luehrs1, Feb 11, 2005.
  1. Luehrs1
    Luehrs1 Registered Member
    Feb 5, 2005
    48
    Jacksonville
    Does anyone know all the steps need to change a '89 Blazer to a carborated setup rather than setup with the computer.
    Patrick
  2. M-1028
    M-1028 1/2 ton status
    Feb 2, 2005
    217
    Sealy Tx
    You have to buy a knew intake because the throttle body has a different bolt pattern than a carb. Unless someone makes a spacer that could convert it over.
  3. Luehrs1
    Feb 5, 2005
    48
    Jacksonville
    I have an edelbrock intake in it right now.
  4. M-1028
    Feb 2, 2005
    217
    Sealy Tx
    That intake was designed for the original TBI not a carb.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Tell you what , if you don't want a computer , and never adjusting the air fuel , and never want to idle on your side , send it to me , I'll send you a carb :D
    I actually LOVE my carb , but if I had the money , I would go fuel injection on both trucks . Your whole truck is setup for it anyway :deal:
  6. M-1028
    Feb 2, 2005
    217
    Sealy Tx
    The actual intake to convert it to a carb has a different bolt pattern. If your valve covers have four bolts in the middle, a normal carburated intake will not work. Jegs has a conversion intake for your application.
  7. eagle mark
    eagle mark 1/2 ton status
    Nov 18, 2004
    3,289
    North Idaho!
    Why do you want to go backwards in technoligy? What's wrong with your TBI?
  8. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Besides a manifold
    You will need a new old style HEI dist .
    You either need An adjustable fuel pressure regulator with a bypass for the fuel return line if you are going to use the stock intank pump. Dont hook it up without the fuel return or a regulator because the pressure is way too high for a carb and or your pump will burn out in a short time without a return line.
    OR
    A low pressure fuel pump designed to be used with a carb.
    I really dont understand Why you would want to go thru all that hassle and $$$ to go back to the Carbeurator stone age.:confused: TBI is way better.
  9. Luehrs1
    Feb 5, 2005
    48
    Jacksonville
    I have been having so many problems with the computer and timing and fuel pumps and so on that i figured it would be easier to switch it out and not deal with sensors and such.
  10. eagle mark
    Nov 18, 2004
    3,289
    North Idaho!
    These GM TBI systems are proven reliable. Other than maybe an O2 sensor every 100,000 to 150,000 miles!
    I have a 93 Chevy Caprice 9C1 police car as a daily driver with 141,000 miles. TBI system very simalar to yours. Received the maintenence records with it. So far I have replaced the O2 sensor, no other record of EFI repair, few fuel filters as maintenece.
    In the end your going to have more work and money going backwards then fixing what you got.
    What's wrong with it? Have you checked for trouble codes?
  11. Luehrs1
    Feb 5, 2005
    48
    Jacksonville
    yea it said it was the o2 sensor but upon further troubleshooting found out the chip was not stock and was bad so i replaced it with the factory one. Also there are headers on it instead of exahust manifolds so the o2 sensor goes out faster and i have a short somewhere that i havent been able to find yet. It is also borred 30 over and is stroked and cant get the timing right. so i figured with all these problems it might be easier to just go back to the simplist form.
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Are you settign the timing where it needs to be for the computer to work right ? Or did you try to set it yourself to try and get performance ? Are the original owner , or did others mess it up , like the wiring etc ? Give all the details , there are computer savvy guys here that know way more about TBI than I forgot about carbs :k5: :k5:
    I would absolutely love a stock one , set to stock settings , I don't need to go fast , just need to climb over rocks :D
  13. Luehrs1
    Feb 5, 2005
    48
    Jacksonville
    I tried to set the timing to the specs but cause of the stroker kit i cant get it right. i know about the problem with the o2 sensor but i dont want to put exhaust manifolds on but it looks like ill have to so that the o2 sensor doesnt burn up. so tomorrow ill know more one i put a new o2 sensor in. if it fixes the problem ill go from there. i did get it like this. i bought it from a friend that got it from a guy that did all sorts of weird things to it. 305 heads on a 350 pluss the headers. so im kind of trying to fix all the mistakes so that i have a decent running truck.
  14. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Ok , you have some motor issues here . I am no expert but I would be willing to bet that some 350 heads , throttle body work like injectors or big block throttle body , fuel pressure regulator , and a chip are in order :dunno:
