Carb/dist swap questions with 700r4
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Doug, Oct 20, 2001.
  1. Doug
    Doug Registered Member
    Sep 1, 2001
    56
    Northern Colorado
    I've currently got a computer controlled Qjet with California emissions and a 700r4. I would like to swap in an older, non computer controlled Qjet and distributer.
    My questions: What are the wires on the transmission. There's on at the rear drivers side corner, and one on the front passenger corner. If I swap to the older stuff, will it affect the transmission?
    Will I open a can of words in any way that I may not have thought of? The passenger side exhaust manifold has what looks like a vacuum operated valve on the end??? Should I swap exhaust manifolds as well?
    Any other helpful hints or suggestions would be welcome.
    '85 K5, 350, 700r4, np208, 10 bolts, as of 10/2001; wish list is extensive.
  2. K5RON
    K5RON 1/2 ton status
    Apr 14, 2001
    219
    Most later Chevy's have that vacuum heat riser thingy on the pass manifold, computer or no computer!
    Ron
    '84 K5......Tree Fitty, SM465/Np205, D44/14BFF, Pro-jection! .....and of coarse no other color than Odie!
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I just did the same swap last week.. No problems...Dan
    If it ain't broke.......Don't fix it....
    <a target="_blank" href=http://coloradok5.com/gallery/Gokartergo>KLICK</a>
