Carb flooding angles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 78Jimmyish, Nov 1, 2001.
  1. 78Jimmyish
    78Jimmyish 1/2 ton status
    Jul 28, 2001
    137
    Rhode Island
    What kind of angle can I expect a Holley (don't know model #) carb to flood at??
  2. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    depends somewhat on the float level.
    basically once the main discharge nozzle is lower then the fuel level it begins to gravity feed.
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    It also depends on which direction you are angled. Nose up/down or leaning left/right. Depending on the model/design of the carb, any one of these can/will vary. Q-Jet can handle the greatest angles in all directions due to design. However, there are various anti-slosh kits (sometimes called off-road kits) which help their various carbs a bit (but in reality it still doesn't come close to the Q-Jet, I know, I've tried). Tricks like lowering your float levels or making other modifications can also help, depending on the carb. Of course this is all just general info and no specific help. As to the Holley, I am not able to help you at all there. I swore off the Holleys years ago...
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
