carb guys: what is this part and how do I make it work
Discussion in 'The Garage' started by MilpitasK5, Sep 23, 2003.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    Its a part that's bolted on to the driver side of the carb. When the throttle returns, it pushes this a little knob type thing back in to make the idle drop back down.
    Mine is kinda sticking and my spring can't return it back in. I press on it and it's kinda hard to push back in but it goes if I push it manually.
    Can I fix it or do I need a new one? What is it called?
    Sorry about the wacked out description but... /forums/images/graemlins/crazy.gif
    TIA
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Is it, a electric solenoid type? If so it's probably the "idle speed up solenoid" for A.C. when the A.C. is on it drag's idle speed down so this compensate's for it. /forums/images/graemlins/grin.gif
  3. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Thanks, that sounds like that would make sense. If I don't use my A.C. is there any way to by-pass it?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah just remove the item totally from your carb.
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Or leave it there, wire it to a switch, and use it for a high idle when crawling.
  6. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Great, thanks for the input!
