Carb help needed
Discussion in 'The Garage' started by 79k5383, Apr 26, 2004.
  1. 79k5383
    79k5383 Registered Member
    Mar 20, 2004
    18
    My motor is in and just about ready to firw, I have a holley 4160 600cfm. Anyone have any pics of the way they rigged the linkage? It would be a great help since that seems to be the only major thing holdin me back at this moment. ANy and all advise much appreciated. /forums/images/graemlins/k5.gif
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    there is a Holley small parts kit to adapt the chev linkage
    I have one here on my 600 but I am uncertain if I am going to swap in a Holley base plate under my propane so I want to hang onto it
    I had the linkage jury rigged for a few years and after trying the Holley parts I highly recommend spending the money on it
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I don't have any pics of it, but I ran a 4160 on my 76 Chevelle Laguna. The throttle was easy to do , the kickdown (th350) I had to improvise . It would be easiest to buy the adapters. I had a w.o.t stick when my homemade linkage bound ( on a surface street /forums/images/graemlins/yikes.gif ) so get it right the first time .
    Here are some Holley part numbers, something will work for you:
    P/N 20-88 Throttle cable bracket - Models 4150 and 4160 carburetors
    P/N 20-89 Throttle return springs (2)
    P/N 20-32 Throttle cable bracket
    P/N 20-44 Throttle cable bracket
    P/N 46-74 Throttle solenoid - use with GM p/n 2060106
    P/N 20-9 Throttle solenoid bracket - use with solenoid p/n 46-74
    P/N 20-47 Throttle solenoid bracket - use with solenoid p/n 46-74
    P/N 20-35 Transmission kickdown throttle linkage
    P/N 20-45 TH-350 Transmission kickdown cable manifold bracket
    P/N 20-95 TH-700R4 Transmission kickdown cable carburetor bracket
    P/N 20-72 Dashpot/Solenoid bracket
    P/N 20-58 Dashpot/Solenoid bracket for Holley model 4160 carburetors
    P/N 20-17 Dashpot/Solenoid bracket for Holley model 4160 carburetors
    P/N 20-112 Billet aluminum throttle cable bracket
    P/N 11-4 Universal Dashpot
    P/N 46-74 Universal Throttle Solenoid
    P/N 26-57 Universal Solenoid and Dashpot Bracket
    P/N 20-36 Throttle and cruise control stud
    P/N 20-37 Throttle stud; 7/32" dia
    P/N 20-38 Throttle stud; 1/4" dia
    P/N 20-39 Throttle stud; 1/4" dia
    P/N 20-40 Transmission kickdown stud
    P/N 20-64 Throttle and cruise control stud
    P/N 20-67 Throttle and cruise control stud
    P/N 20-2 Throttle ball assortment
    P/N 26-104-10 Throttle cable clip
    P/N 26-103 Throttle lever stud bushing
    Most speed shops have these in stock for you to look at. /forums/images/graemlins/thumb.gif
