Carb Help Needed
Discussion in 'The Garage' started by coptezr, Jul 26, 2005.
Which carb
  1. Holly TruckAvenger
    11 vote(s)
    39.3%
  2. Edelbrock
    6 vote(s)
    21.4%
  3. BarryGrant
    0 vote(s)
    0.0%
  4. Other
    11 vote(s)
    39.3%
  1. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    I need to get a new carb i have a Barry Grant 525cfm road demon its ok but on inclines and delicnes, it just plain sucks. I was looking at the holly truck avenger anyone have any complaints. What would be a better cfm?
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    your motor built any or do you plan on building on it?
  3. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    I voted other because if I was buying a new carb, I would get a Qjet from SMI Carburetor. They build the carburetor for your vehicle. A Stage I is $325 and a Stage II is $365. Less money than your other choices. When you order the carb you give them all of the info on your application: cam specs, motor, gearing, tire size, vehicle weight, elevation, etc... Now I haven't owned one myself, I'm just saying that's what I would do.
    If I had to choose from your list, I would probably use the Holley.
    Demons are awesome street carbs, but like you they didn't work for me on the trail either. I actually only had problems with inclines but not declines.
  4. coptezr
    Jan 13, 2005
    342
    my motor is a stock crate 350 with hooker headers and edlebrock rmp air gap intake.
  5. coptezr
    Jan 13, 2005
    342
    Those smi qjets are 750 cfm isnt that wasy to much for my truck?
  6. coptezr
    Jan 13, 2005
    342
    Or should i go tbi?
  7. coptezr
    Jan 13, 2005
    342
  8. primetime
    primetime Registered Member
    Jul 18, 2005
    22
    sa,tx.
    GO TBI IF YOU HAVE XTRA DENERO$.
    I HAD THE 770CARB TRUCK AVENGER, I HATED IT!!
    i went back to my edelbrock & installed the spring, needle & seat.
    it works great.
    holley needs alot of adjsuting during the winter & summer.
    edelbrock their is very little adjustment & easy.
    holly came out w/ 550 truck avenger. this might better suit your needs.
    a 770 is to big, its meant for a strocker or big block
    find a used 600 edelbock $50-75 rebuild kit $35.00 needle,spring $25.00
    and u will have a nice off roading carb for $135.00 1/3 the cost of a new
    670 truck avenger
  9. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    Not with a Q-Jet
  10. dyeager535
    26,980
    Stock on all GM vehicles was the 750 or 800CFM (with 4 barrel carb of course) no matter what size the engine, so no, the Q-jet won't be too big.
    Heck, 305 trucks were getting the 800CFM's while 400+ CID motors were getting 750's. :)
  11. coptezr
    Jan 13, 2005
    342
    hmm will i get more power out of a 600+ cfm carb then my 525cfm ?
  12. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Go to a local dirt track and start asking around who can tune carbs quads to be specific usually you can find someone who really knows how to work magic on a quad, that way if you ever have any problems you can go back, if you can't find someone local go with the SMI quad also Barry Grant has a new carb for off road use that uses alot of the same principles as the Holly truck avenger
  13. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    From what I have seen the Truck Avenger is a great carb. It is just difficult to tune but if it is tuned correctly you should be very happy with it.
    ....And ya 770 cfm is almost certainly too much carb.
    Blazinzuk's got a good idea about getting stuff tuned. Most dirt track racers are low buck guys and willing to help for a couple of bucks or just a few beers.
  14. dyeager535
    26,980
    Perhaps. Some engine builds I've seen performed better (power-wise anyways) with carbs that are supposedly WAY too big for the engine.
    In reality most q-jets were physically limited as to how much they can flow (easily corrected) but I don't know that anyone has data as to how much. Each vehicle application seemed to have a different limitation.
    You'll start to see the Q-jet bias come out on this sight due to their very good off-road performance, and it's easy to see why, with them being as common as they are.
    If you keep your eyes open, a rebuildable core can be had for $5, and a rebuild kit for around $20, so if you like to do things yourself, that might be a way to go.
  15. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    I vote for holley truck avenger if a carb is the way you are going. If you have the cash I would go efi. That being said, I had a q-jet and it worked great for moderate wheeling but with the really steep stuff it left me high and dry. Went to a 670 cfm truck avenger and works well, does take some tuning. Once dialed in my is working good on my 350 cid. BTW fuel milage is worse than with a 770 cfm Q-jet.
  16. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    If i could start over i would get a Predator carb., they only supply as much air/fuel as the motor needs and are great for off-roading but their kinda pricey. :bow:
  17. coptezr
    Jan 13, 2005
    342
    thanks keep the info coming :D
  18. rodney chambers
    rodney chambers Registered Member
    Jun 23, 2005
    50
    northeast oklahoma
    i have a truck avenger and it has developed a flat spot from idle. holley techline says some -1 carbs had this problem. i'm thinking of modifying power valve linkage to come on a little quicker. what do you guys think?
  19. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    My freshly rebuilt Q-Jet is plenty of carb for my truck, I just can't seem to find anyone that can tune it properly. No matter where I take it or what I do, it still hesitates horribly. Other than the fierce hesitation, I haven't really had it on any serious inclines to test it's abilities. I hear they're pretty dang good on inclines for being a factory carb.
  20. lak2004
    lak2004 1/2 ton status
    Aug 31, 2006
    3,809
    Durango, CO
    Go some sort of FI tbi, tpi anything but a carb and dont ever look back :thumb:
