carb help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoSmog73, Sep 28, 2001.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Hi can anyone help with a rodchester(ya ya It's not worth it) But for now it's what I have. It runs and starts up great but there seems to be a slight studder at take off or rolling cal stop.(For a 73 350 blazer)
  2. NOT4SHW
    NOT4SHW Guest
    This may sound kinda dumb but I thought I had carb problems because I had the same hesitations. Check and make sure your spark plugs are good. My engine is old and tired so the worn rings and such had caused the plugs to foul, yea they all looked like someone had taken them and rubbed them in dirt/grease and put them back in the heads. I replaced them and it runs great. I'll be so glad when I get my new engine is finished!
    '79 K5,13 1/2" lift, 39.5 TSL's,15x12 Eagles,350,t-350,warn 8274,39.5 Boggers for wheeling!
  3. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    thanks have a set in the garage
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Make sure you have enough initial timing. I have been surprised to discover that most of my own and other's "carb problems" are honestly ignition-related.
    Tim
  5. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    This may or may not help, but some carbs need the addition of a delay valve in the vacuum line controlling the EGR actuation at part throttle. This keeps the EGR from injecting exhaust into the intake too soon, causing a slight "stumble". Just my $0.02
    - Alan
    '82 K10 Suburban Silverado (AKA U.S.S. Nimitz)
    Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut!
