carb help?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoSmog73, Oct 21, 2001.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Where can I get an accelerater pump for a 73 blazer rodchester carb? Are they in the carb rebuild kits or are they seperate? I checked at kragen and pep boys and no luck?
  2. 1bad82k5
    1bad82k5 1/2 ton status
    May 8, 2001
    185
    MT
    You will probably have to get a whole kit. I am yet to see the accelerator pumps individually, however, this does not mean that they aren't available.
    eric
    Don't get me started, you know how i get.
    82k5, 14bff, d44, sm465, np205, 300hp350, rust
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    You can buy them here: <a target="_blank" href=http://www.quadrajet.com/Quads/R4accpump.asp>http://www.quadrajet.com/Quads/R4accpump.asp</a>, but I would recommend just going AutoZone and buying a complete rebuild kit for about $20. Then you will have a new air horn gasket if you need it.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  4. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    When I bought the rebuild kit for my Holley 600, it did not include the accel pump.
    Autozone had the accel pump seperately, and it was very cheap (under $10 if I remember correctly?)
    Thomas.
    -- '84 1-Ton Blazer --
    When the goin' gets tough,
    the tough go 1-Ton [​IMG]
  5. Blazer1970
    1,600
    Old Mission, MI
    It comes with the Q-Jet kits.
    Tim
    87 Burb 4X4 350
  6. dyeager535
    26,979
    If you do this, CAREFULLY compare the accelerator pump in the kit to the one you are removing. I bought a kit that had the wrong length accelerator pump in it. I just swapped the pump cup/seal over to the original one. The shaft doesn't wear.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
