Carb, Idle problem?
Discussion in 'The Garage' started by Confedneck, Aug 10, 2003.
  1. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    so im drivin along today and pull into my buddies driveway, where lots of bad things happen to trucks..just ask him...anyways i put my foot on the clutch to pull it out of gear and roll in the driveway, and the idles at 2k..so i fiddled with the little screw on the passenger front of the carb.. and it seemed to help...then it did it again, only at 1200 this time..it seems to correct itself after hard driving...its a holley 4 barrel carb, who knows what kind, and i just did an atf intake cleaning with it a couple weeks ago...any ideas?
  2. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    How old are your plugs and what kind of shape are they in? Is your return spring getting weak? Dirty carb maybe?
    Kris
  3. Confedneck
    Nov 1, 2002
    5,236
    carbs clean...who knows about the plugs and the return springs are ok..the throttle was closed to the idle position when i popped the hood, i was thinking sticky needles/seats possible? i might try an aerosol overhaul on the carb tomorrow..
  4. Confedneck
    Nov 1, 2002
    5,236
    well today i bought some marine/automotive sea foam deep clean..hosed the carb down nice and it hasnt done it yet today..also changed the air filter out...its amazing what 12 dollars in parts and 20 minutes in time can do for throttle response.. /forums/images/graemlins/thumb.gif
