carb idles at 4500
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sburk340, Nov 11, 2002.
  1. sburk340
    sburk340 Registered Member
    Nov 5, 2002
    13
    Texas
    My carb. idles at about 4500-5000 rpms, and not sure why. I took off the air filter and put it back on, before that it was running fine. I'm not sure if I knocked any wires loose or what? If anyone knows what to do it would help me a lot. Thanks /forums/images/graemlins/k5.gif sburk302@yahoo.com
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    make sure your cruise control linkage from the carb to the intake diaphram isn't bound up.
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Yeah, i was gonna suggest the same thing...the rod on mine fell off on the highway, got hung up on a bracket and held the throttle open...kinda sucked
  4. sburk340
    Nov 5, 2002
    13
    Texas
    thanks a lot, it's dark so i can't see it tonight, but i'll check in the mourning, thanks again /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    If it's not the cruise linkage, check the butterflies themselves to see if they are stuck open (ie- something in there, busted return spring, ?). To "idle" at 4500-5000rpms /forums/images/graemlins/shocked.gif sounds like the butterflies are stuck at darn near w.o.t. (wide open throttle)
  6. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    also check to see if the air cleaner is not holding the accelerator pump or maybe the air cleaner is not fully seated
