Carb / ignition question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ellero, May 4, 2007.
  1. ellero
    ellero Registered Member
    Jan 25, 2004
    66
    Covington, Georgia
    I have been told that the computer controlled Q-jet sucks and I need to get a non computer controlled Q-jet. I did that. Before I change out the carb, what other things do I need to get to make the truck run right not that I will be getting rid of the computer stuff and where is the best place to get them?
  2. bigblock72
    bigblock72 1/2 ton status Premium Member GMOTM Winner
    Oct 18, 2005
    1,235
    59
    American Fork, Utah
    IF you get rid of the feedback carb then you'll have to change the distributor to a non computer HEI. Both can be bought at any parts store, just order one for a late 70's blazer. Or the wrecking yard off of a blazer or light duty pickup.
    You will have to figure something for the lockup on the 700r4 since the computer won't be able to run it, several different kits around for doing this.
    Passing emissions may be a problem depending on how picky they are in your neck of the woods.
    If it were mine I'd look real close at converting over TBI, I think that'll be the best way to get around most of your problems and have the added benefit of not having to deal with a carb.
  3. ellero
    Jan 25, 2004
    66
    Covington, Georgia
    Well I am moving to Georgia and they dont know what emissions checks are where I will be. Already have my GA plates. Also the tranny was swapped out for a t-350 with a 203 and part time kit. I broke my 700R4 in half. Oops.
  4. K85 Octane
    K85 Octane Tacklin' Fuel Premium Member GMOTM Winner
    Nov 2, 2009
    11,407
    791
    Los Angeles/ Pasadena
    re-use an old thread, hope no body minds.
    I have a CA 85 blazer w/ all the nifty ideas GM thought to put on it. Problem is, I don't want any of it. Setting smog conversation aside, I'm looking to drop in a stock '78 q-jet with matching distributor. I'll find a drivers side exhaust manifold from a truck to delete the O2 sensor. Passenger side is cracked anyway. I already have gauges from a late 70's p/u with tach and no engine light. Truck comes with cat and stays with cat. As far as the 700r4 goes, what will need to be modified etc to get it to work? EX: Shift cable, kickdown, etc? Will changing these pieces mess with my gauges or any other wiring that might be tied into the missing parts? Thanks for any help cause I'm about out of searched thread. (PS) just bought truck, what a mess
