carb issues
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sanjoseblazer, Apr 15, 2002.
  1. sanjoseblazer
    sanjoseblazer Registered Member
    Apr 15, 2002
    6
    San Jose, CA
    have an '85 full size blazer and having issues with my carb, want to know if i can replace it with an aftermarket one?? i've been told by several tech guys that i cant. by the way it runs very rich and was told it leaks a little of gas. sorry not a mechanic. just a guy trying to get his rig ready for the summer.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Before you just go and replace your carb, why don't you give us an idea of what's wrong? A list of symptoms might help us troubleshoot a bit.....
    And take couple of sconds and fill out your profile a bit. We have abunch of members in CA who might live right around the corner from you!!!! Your profile info helps us help you./forums/images/icons/smile.gif
  3. sanjoseblazer
    Apr 15, 2002
    6
    San Jose, CA
    thanks i added the problems, by the way it runs rich and leaks a little bit of gas from the carb.
  4. Can Can
    15,552
    136
    Don't feel bad, brother, I'm not a mechanic either/forums/images/icons/tongue.gif. If you have a stock quadrajet carb, there are adjustment screws on the front of the body that allows you to adjust how rich the motor runs. Where is the leak coming from? Is it leaking to the outside of the carb or have you been told it's an internal leak?
  5. sanjoseblazer
    Apr 15, 2002
    6
    San Jose, CA
    been told its an internal leak, that i need a new one or rebuild the one i have, if i can take advantage of getting a new one that will work great. i was told they dont make one that will work on my truck, i have 3 electrical plugs into my carb.
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Q-jets often leak out the plugs in the bottom of the float bowl. If the leak is bad enough the intake vacume would suck fuel out the bottom of the carb making it run rich. The way to solve it is to epoxy the plugs so they don't leak...someone might have some pics...I have yet to rebuild my carb.
  7. sanjoseblazer
    Apr 15, 2002
    6
    San Jose, CA
    thanks i'll take a look and check on it. what do you recomend to plug up the leak if thats what it is??
  8. Can Can
    15,552
    136
    JBWeld works wonders for sealing up the well plugs.....
  9. sanjoseblazer
    Apr 15, 2002
    6
    San Jose, CA
    thanks i appreciate the advice.
  10. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I'd say rebuild what you have. The Q-jet is a pretty good off-road carb. I think my last rebuild kit (Before I went Fuel injection) was around $25. Look on the side of the carb where your throttle linkage connects and you should see some numbers. Give these numbers to the people at the parts store and they should be able to hook you up with the right kit. The kit should also have an exploded view of the carb to help rebuild it. The two screws on the front only affect the idle mixture so it sound like you are leaking on the inside (the carb not you). Good luck.
  11. sanjoseblazer
    Apr 15, 2002
    6
    San Jose, CA
    thanks buddy, looks like that is going to be my best bet with the prices i've been qouted doing it myself would be lots cheaper.
    thanks again
