carb on hills?
Discussion in 'The Garage' started by 4trolls, Apr 17, 2005.
  1. 4trolls
    4trolls 1/2 ton status
    Nov 13, 2002
    190
    vancouver wa
    I have an Eldlbrock, and it stalls on steep angles, my friends carb does not stall on the same angles. My question is what can I do to make mine better on the hills?
  2. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    i had some problems with my edelbrock. solved 98% of them with the spring loaded neddles and seats kit.
  3. 4trolls
    Nov 13, 2002
    190
    vancouver wa
    what does that kit do? and thanks for the reply
  4. sweetk30
    Nov 1, 2004
    25,537
    536
    the neddles float hang on the flots and can at severe angles and or bounching stay open and flood out the motor. the spring loaded will be much harder to get to float open under those conditions. the kit is easy and cheep. this is just my opinon and others will click in soon. so best to see what others say as thay run these to.
  5. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I'm running the same kit and it definitely helps. It might not be as good as some other carbs, but it works up to plenty steep angles for me. I have had it start to flood with the kit, it helps, but does not totally eliminate it.
  6. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I had the same problem, my edelbrock would stall on steep angles and technical obstacles. This was very dangerous since my steering and brakes were greatly diminished. I opted to trade my edelbrock with a local guy in Vegas for a quadrajet. I rebuilt it threw it on and tuned it in. Since then I have never stalled it, no matter what the angle. The Edelbrock was definetly an easier to tune/maintain carb, but the benefits of the quadrajet have been well worth the trade.
    I would recommend swapping in a Q-jet. Most will agree they are the best only second to the Holley Off Road carb for wheeling.
    Just my .02 :)
    Jeff
  7. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    holley all the way.
    sell it... buy a truck avenger.
  8. 4trolls
    Nov 13, 2002
    190
    vancouver wa
    tell me more about this truck avenger, I've hered this advise a couple time now. how does it compair to the q-jet? mine dies on technical obstacles, thats the worst part. I would go tbi but it sounds like a can of worms. I just finnished an 5 year build of a jeep and I dont realy want another build up.
  9. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Read this
    If you are on a tight budget I would recommend just getting a q-jet from a junk yard and rebuild it. It would be a lot cheaper and would give you similar results.
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    take it off, put a QJet on the engine, and leave the Eddy in the back of the truck. use it as a wheel chock if the truck ever dies with a QJet on it.
