Carb or Distributor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chevit, Dec 9, 2003.
  1. Chevit
    Chevit 1/2 ton status
    Dec 10, 2001
    1,492
    dnaltroP, nogerO
    This has really buggin me, lately I will be driven along put my foot into the throttle and my blazer just stumbles along and somtmes it will pop up thru the carb. This dosn't happen all the time but often, after the rig is warmed up. The timing is right on, but I have had problems with the choke. Any ideas??
    84 K5
    Q Jet
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Mine does the same thing, except mine pops out the exhaust and not out the carb. I was told to check the intake gasket and carb base gasket for leaks. With the engine all warmed up, spray starter fluid at the gaskets, if the rpm's go up, you gotta leak. I still need to do this myself, just haven't had time /forums/images/graemlins/shocked.gif
  3. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    My K5 did that when I was trying to start it, and I ended up putting it a new coil and spark plug wires. It works great now with nothing coming out of the carb.
  4. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    My Crew Cab has recently started doing something similar. When it's warmed up and I'm driving, if I get my foot into it or start pulling a grade on the highway, it will backfire through the carb. I'm worried about it being a cam lobe starting to go flat.
    I just took the Q-jet off and put an Edelbrock on it a couple hours ago... have yet to go and drive it to see if it's changed or not. If not, Im changing cap, rotor and coil while I'm at it, and plugs/wires.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    is the EST system all still connected and working ?
    might even module messing up, id try another one, heat maybe getting to it
  6. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Sounds an awful lot like wires. Swap 'em out, and while you're at it, replace the cap and rotor just in case.
  7. Chevit
    Dec 10, 2001
    1,492
    dnaltroP, nogerO
    I am leaning toward the coil, the cap, rotor, wires, are not that old. My bro-in-law suggested that I put some white grease on the weights in the distributor which I did to prevent the from sticking which did not help. I think I will pull the spark plugs to see if they are soaked in gas, that would tell me if the coil is bad...
  8. mountainexplorer
    Nov 14, 2001
    4,903
    My carb swap worked on mine... for about 5 minutes, then it started running bad again when it got heated up. Re-timed it, replaced the coil, still runs the same. So I decided to replace the plugs (which I soon realized I had replaced about 3 years ago... oops) and most of the wire boots were so hard/brittle that they broke. But its still not running right.
    Think your problem (and possibly mine) could be the ignition module? (like R72K5 pointed out) Thats the last thing I have left to replace.
