Carb or Engine gurus??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SCOOBYDANNN, Dec 3, 2001.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    W/ the truck warmed up when at idle, if i stomp on the gas there is a studder, an empty spot, like not rapping out evenly only at the beginning. if i slowly lay on the gas it dosn't do it, only when i stomp on it. My somewhat educated guess is either the carb or timing. Can anyone help me?
    p.s. i have a mild 4x4 cam and quadrjet, don't know timing cause i have no timing tab
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
    It's all fun and games till somone loses an eye!
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Sounds like your guess is pretty close. First with the engine not running look down the throat of the carb and pull back on the throttle linkage. You should get a good healthy squirt of gas down the primary(small holes) carb throat. If you dont get a good stream of gas as you pull back on the accelator linkage..the accelarator pump is bad in the carb. That will cause a bog on acceleration.
    If you are getting a good squirt of gas the timing may be off.
    If the timing is too far retarded it can cause a bog , lack of power, bad gas milage,
    If it is too far advanced it will ping and can backfire.
    You said you dont have a timing tab. you really ought to get one so you know your engine is properly timed.
    If you have a vacume guade you can set the timing without a timing light or a tab.
    Hook up the vacume guage. With the engine at idle. Move the distributor till you get the highest reading on the guage. Leave the distributor at the position where the highest reading was obtained and tighten it down that usually gets the timing very close to where it should be
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze>http://coloradok5.com/gallery/Thunders-Blaze</a>
    <font color=blue>NEVADA: Where the pavement ends, and the West begins.</font color=blue>
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Get a Holley!
    With the problem your describing it sounds like the accelerator pump..
    If you had a Holley you can get the assortment of like 10 different accelerator pump cams, and dial it in until that off-idle sputter is gone.
    It's when you stomp on it quick, it opens up those butterflys, and the accelerator pump can't squirt enough gas to compensate for that temporary lean condition.
    Don't know what to say about that Q-jet.
  4. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Cold weather? Did this condition happen when the weather changed? Or does it do it even after a high-way driveing? (totaly warmed-up) -The answers could help diag. the problem, could be timing or fuel rellated. Fuel related problems could occure when the temp changes. Timeing probably would happen all the time, regardess of the temp.
    Excellerator pump-shot problem: Whan you stomp on the gas- hard, it would go way-lean. Because, air will flow faster than fuel and the feul will condinsate on the port walls, that is all-ready in the ports. So, the excellerator pump adds more fuel "right-now", to cover up that lean condition. To check- as stated above- work the thottle by-hand and check for the pump-shot.
    Also, check for a vacume leak. Check hoses, gaskets and the throttle blades for play. Any vacume leak will also cause the sys to go lean- and might have the same effect, all the time, but when cold it might be exaggerated
    <font color=blue>Twiz</font color=blue>
    Can't get it up?
    So, drop it in
    gear.
  5. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    i'm having a similar problem and what does the squirt of gas look like? just wonderin. thanx in advance. later.
    jacob
    what is that low rider doing under my k5?
    wow nice lil jap car. whats it good for?
  6. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Q-jet? If so. From the top, look into the choke tower, open the choke (if closed) look inside, there are 2 screws inside the choke-tower, just about a 1/4 inch in (towereds the center) are the excellerator pump shot out-put ports. They are very hard to see. Work the thorttle by hand, with the float bowl full, there should be a solid shot of fuel, just like a squirt-gun, aimed at the boosters.
    Sorry Thunder, didn't mean to steel your -um- thunder, but I'm on the subject my-self. (and need the post count to keep up with Pureinsanity)
    Can't get it up?
    So, drop it in
    gear.
  7. k5ntexas
    Oct 29, 2001
    2,517
    ok thanx. i'm gonna look at it this weekend. i ain't got time. if i got any questions i'll post and see if i can't fix this thing to run at its peak mpg with good enough power. i wanna fine tune it so i can save as much to get my 383 stroker. thanx again. later.
    jacob.
    p.s. when i get my 383 i'll become a member. thats a guarantee. lol.
  8. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Cold-Weather--no it was doing it before it got cold, it only does it at idle and i stomp on it. I can even go kinda fast and it won't do it, also when im actually driving it and have to switch gears it does it. im gonna check the things you told me and hopefully get it fixed. also, if i let the truck sit overnight (mostly sits for a couple days though) it takes a good while to start (like 2 turns for 10 sec and usually starts on the 3rd) could that be a symptom also?
    thanks
    It's all fun and games till someone loses an eye!
  9. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Danny,
    Those are 2 separate probs - but you can fix them both when you pull it off....
    The sitting/hard starting thing is cuz the float bowl is drying up. Typically leaks out the well plugs at the base of the float bowl. JB Weld the plugs to stop leakage.
    As far as the stumble, replace the accelerator pump and put the rod in the shorter hole on the lever arm for max squirt.
    Oh, and don't get a Holley!
    Marv
  10. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    They do make good wheel chocks...[​IMG]
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  11. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    unless you actaully enjoy replaceing the power valve everyday!
    -zakk
    '77 1-Ton K5
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  12. mudmover
    mudmover Registered Member
    May 13, 2001
    20
    Southern California
    if your accel pump seems to be working, you can also check the choke pull off too. if the secondary flaps open (the ones on the top of the carb, over the secondaries) immediately instead of gradually the sudden rush of air will lean it out and cause a bog. good luck to you. Oh, and put my vote in for not putting a holley on your truck too. great for a race car, but sucks for a 4x4. (too easy for the fuel to spill out of the vent holes and stall your engine.)
    Mudmover
    What do you mean you cant run <font color=red>35's</font color=red> and an <font color=red>easy locker</font color=red> and <font color=red>3:08's</font color=red> in a <font color=red>10 bolt</font color=red>?[​IMG]
  13. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    OK, great post guys. I have a similar problem. After I start my rig, in the morning, I can drive a few blocks and everything is fine. But, as soon as I stomp on it, like after a slow California Stop, it bogs down, seems to back fire a little but will accelerate fine once I back off the gas. After warm up, it runs fine and does not bog down anymore. The Qjet is a rebuild from a very good shop. Timing is dead on and I have a new HEI Accell Distributor. Thanks for any info.
    <a target="_blank" href=http://www.geocities.com/keywestk5/KeyWestK5.html>http://www.geocities.com/keywestk5/KeyWestK5.html</a>
    So I says to him, I said, "get your own monkey."
    1986 K5, 350 GM Crate, 700R4, NP208
  14. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Tell me about the Holley---ii hated that darn thing. so everyone seems to agree it's the carb. I have a warranty w/ autozone w/ this one--should i go get a "new" one or shuld I try and open it up?[​IMG]
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Get rid of it. I absolutely hate Holley carbs just from working on them at my old job (I worked on boats).
    Every one of them that isn't used for drag racing (WOT all the time) is a worthless hunk of crap.
    Tim
  16. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    how often does your POS backfire and kill powervalves?
    just for you, holley sells a kit for people with dead engines that back fire a lot.
    I have NEVER had a dead powervalve, and i only run Holleys
  17. BlazingItaly
    BlazingItaly Registered Member
    Apr 7, 2000
    35
    Milan Italy
    Anybody tought about the choke pull-off, mine was stuck and the choke plate wouldn't open even when warm.
    just my tought
    Luca
  18. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Try the warranty swap.... If they'll do it, that would be quickest!
    ...sides, you don't need to spend your time building carbs.... you got a 'cage to build!
    Marv
