Carb Problem ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chevit, Jan 16, 2002.
  1. Chevit
    Chevit 1/2 ton status
    Dec 10, 2001
    1,492
    dnaltroP, nogerO
    I have a rebiult Q-Jet purchased in Feb. My newest problem is lack of power. I was towing my trailer last weekend and I could not get going over 55 mph. I thought that maybe I had gotten some bad gas so i dumped in some gas drier and carb cleaner pulled in the drive way and power braked it, and the blazer just stumbled and almost died then a nice big cloud of black smoke. The thing that puzzels me is that it will run fine one day and the next it will not run for sh1t. Any ideas
    84 K5, Crate 350, 700r tranny, 3.73 rear, 32 11.50 15, Q-jet
  2. 1bigk10
    1bigk10 1/2 ton status
    Dec 20, 2001
    151
    Medford Oregon
    Check timing? Readjust air/feul mixture? Try running Premium? Check plugs If all black way to rich, if all white to lean, if kinda golden just about right. Check plug gap?
    Happy Wheelin.[​IMG]
    1982 K10 Silverado. [​IMG] 327 SHPE powerplant SM465/205,15"custom lift 38.5"TSL/SWAMPERS 12boltrearD44 front,3.73 gears.
  3. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    try changing both gas filters, the one in th carb, and the one in line(if you have one) you could also check your hei and see if everythings ok, look for massive carbon deposits etc.
    beligerence doesn't justify intelligence.
    <font color=blue>wheelers hate posers.</font color=blue>
    <font color=red>79k15/400/700r4/205/38.5</font color=red>
  4. dyeager535
    26,979
    Cat converter being plugged can cause problems with higher speed/loss of power. On/Off poor running coul dbe timing, I just dealt with that, really rich running sometimes, other times fine. Distributor components were ALL messed up, haven't had probs since I "rebuilt" the top end of the distributor. Can't hurt to go in and check out the cap, rotor, mechanical advance, as well as checking for spark and fouled plugs.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  5. Chevit
    Dec 10, 2001
    1,492
    dnaltroP, nogerO
    The cat is only 4-5 months old I will check the distributer that is the only thing on this rig that has not been replaced.
    Thanks for the replies
