Carb Problem
Discussion in 'The Garage' started by 89Jimmy, Jun 27, 2003.
  1. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    Hello,
    I 've got a drivability problem with my '85. 350, truck avenger carb, edelbrock performer intake, MSD dist. & ignition box. Carb was new Feb 03. It's been running great. I ran out of gas today,(while next in line at the pump.) Pushed the truck up and filled up. It started slow, as you'ld expect. But would not idle. I had to start it while holding the throttle about 3/4 open. Acted flooded. It was running very poorly and I wasn't far from home so I got a ride and went back 3 or 4 hours later. The truck was cold by then and would idle, but not good. By the time I got home,( about 5 minutes), it would stall at idle and blew black exhaust, (choke smoke), at 3000 rpm. Would not run under 2500-3000. I tapped the carb, thinking a stuck float. No difference. Ideas? Thanks in advance.
    John
  2. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    sounds like trash got sucked into the carb. get a gasket set and pull the bowls, clean it out throughly and be sure to put a good filter on the fuel line..
  3. 89Jimmy
    192
    I've got an stock chevy efi filter inline, but I'm willing to try anything. Is the cleaning just in the float bowls or also metering plates ? I don't know much about carbs.
    John
  4. 89Jimmy
    192
    Checked further this morning. When I crank the engine gas pours out of the vent tube. Float stuck? Thanks.
    John
  5. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    You are correct sir. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
