Carb Question (not the Q-jet vs Holley debate)
Discussion in 'The Garage' started by mr_clean, May 20, 2005.
  1. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    I'm about to order my carb. I'm thinking of getting the Jet Stage 2 Q-jet.
    Just wanted to know whether to order the 750 or 795 CFM version?
    Engine is a freshly rebuilt 350
    RV Cam
    Flat top pistons
    Vortec heads
    Performer manifold
    Exhaust will (most likely) be dual 2.5", Headers, and flowmasters...
    Will 45 cfm's make a difference?
    Also maybe someone can answer this for me...
    Why do Q-Jets run so much bigger on cfm's for the same engine as Holleys?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Ya probably don't need the bigger one , you will never see an rpm where ya can use it on trails or stoplight to stoplight . But you can run it if ya want to for bragging rights and it will run good even if you had less cubes .
    They can run more cfm on a smaller motor with a Q-jet due to the smaller primaries , and the fact that the secondaries only flow as needed . And by having each GM divisions carbs in any particular year or era using the same basic casting , you just changed the tuning on each model . \
    They changed a few times over the years , early divorced choke , hot stove choke , hot stove and bowl vent , electric choke and bowl vent , then CCC compu carbs . And BOP have a front inlet instead of Chevy's side inlet for fuel .
  3. mr_clean
    Sep 21, 2003
    348
    Sacramento, CA
    Thanks for the info Paul!!!
    I've always wondered why stock 350's came with 750 - 795 cfm q-jets but if you throw a 750 Holley on there you'll choke it out if you ever get on it. Makes perfect sense.
