Carb question
Discussion in 'The Garage' started by anjieandjohn, Oct 20, 2005.
  1. anjieandjohn
    anjieandjohn Registered Member
    Oct 31, 2004
    61
    Virginia Beach
    Alright...I admit it, I am a dummy when it comes to a lot of things...just ask my wife....I want to change out the stock quad carb and intake and replace it with something a little better and not so many vacuum lines to deal with....any suggestions as I dont have to worry about emmissions to much here. I will be doing this in conjuction with a rebuild....Thanks for the help..
  2. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    When you say quad do you mean q-jet ? If so there isnt a better carb. Rebuild yours or get the edelbrock q- jet. Most of the reman's from parts stores seem to suck so I dont recomend them myself. Cap unused fittings.
  3. mrk5
    Apr 20, 2004
    12,333
    1,043
    Northern Colorado
    There are 2 options I would consider:
    #1: Get a Q-jet from a place called SMI Carburetor. If you are really into rock crawling, install it backwards.
    #2: Get a Holley Truck Avenger, but make double damn sure the list number on the air horn is 90670-2. Emphasis on the -2. I would go with this option if you are after street performance along with trail capablity.
    I will say that a well setup Q-jet can give you plenty good enough performance.
  4. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    I forgot about SMI, I read an article on those guy's once, sound's top notch. What about the " JET" reman's ? are they any good ?
  5. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    I like the Edelbrock Performer Air Gap manifold. And I would say the Holley truck avenger or a good rebuilt Q-Jet!!
  6. mrk5
    Apr 20, 2004
    12,333
    1,043
    Northern Colorado
    I was reading an old Chevy High Perfomance magazine online. It was about Qjets and they were following the rebuild of theirs being done my Jet Performance. The name of the guy doing the work was Sean Murphy, and they called him their Qjet guru. I've always wondered if he started his own place.
  7. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    That's the guy, he's SMI. BTW, your gearing sounds fine, remove your front drive shaft and your good to go. :haha:
