Carb spacer?
Discussion in 'The Garage' started by odoa3, Jun 17, 2005.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    I have a 350 in my 75 K5 with a Edelbrock Performer 1406 (600 cfm/electric choke.) I have a dual plane spread bore Weind intake manifold. There is a spacer with four holes between the carb and manifold. Couple questions:
    1. Why is the spacer there? What purpose does it serve?
    2. Is it a benefit or simply a restriction?
    I am mid carb rebuild and wondering if I should stick the spacer back on or if it does more harm then good. Any info. would be helpful as I am hoping to take it out for the first time tomorrow. Thanks.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    its there for two purposes. One is to insulate the carb from the manifold heat. Cooler fuel, can mean more power or worse atomization. Two is that adding a four hole spacer and spacing away from the manifold that bit is suppossed to increase torque and throttle response. Never tried it myself. I intend to on the 383 when I get it running.
  3. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Thanks, Sled Dog.... guess I will keep it on. :thumb:
  4. icer97
    icer97 1/2 ton status
    Jun 15, 2005
    116
    Missouri
    I had to run a spacer for clearance reasons. My carb wouldnt bolt directly to my manifold, the linkage would bind.
  5. google
    google 1/2 ton status
    May 19, 2005
    805
    Arizona
    Same here only it wasn't linkage. I had to run the spacer and an extra thick gasket because of some strangly placed plate bolted to my intake. Something for the vette it used to belong to I suppose. Tried to take it off, but it had a gasket and holes underneath.?.?. Dunno. AND, I don't think the carb fits properly without the spacer anyway.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    EGR block off plate. It often gets in the way of carbs. No idea why aftermarkets design them in such a stupid way. I was able to modify the one on my Edelbrock Performer intake to clear a carb.
  7. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I am going to run a spacer on the Performer RPM....One reason is that I need more clearance for the vaccum port for the brakes, and I want both sides of the motor to be able to pull from the common plenum it will create....
  8. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Well...lets see here, you have a square bore carb and a spread bore manifold.
    Usually the spread bore manifolds will accept a square bore carb but the Weiand may require the spacer/adapter.
    There are 3 types of spacers....open, 4-hole and 4-hole tapered depending on the intended purpose.
    All of them will raise the carburetor a minimum of 1",
    I run a 4-hole tapered version which is specially designed to work with a large cfm carburetor and Edelbrock Performer RPM manifold or the Dart Kool-Kan manifold.
    both of these manifolds have a small window cut in the top of the plenum divider wall and the tapered 4-hole spacer greatly improves vacuum signal at the carb with this setup.
    generally speaking spacers are used to increase top-end but the engine will let u know if it likes it or not
  9. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Thanks for all the replies and info. I rebuilt the carb and put the spacer back on. Seems to be running better. Man, there are a lot of parts to the Performer carbs. :D
