carb spacer?
Discussion in 'The Garage' started by pismorat, Oct 24, 2003.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    I have the stock Rochester 4 barrel on an Edelbrock Performer manifold, are there any advantages to running a spacer? And if so, what kind? I have heard mixed things. /forums/images/graemlins/truck.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    carb spacers allow for the fuel and air to mix better, and generally improve fuel atomization allowing for a cleaner mixture and more complete combustion..have a 2" spacer laying around that im gonna use when i do my carb and intake swap..
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Carb spacers are also good for keeping the carb away from the intake heat keeping it cooler.
    A spacer w/ 1 big hole will increase top end RPM power. A 2 sided one will help increase mid range, where as a 4 hole will increase lower PRM perfomance and individual venturi signal.
    Confused yet? /forums/images/graemlins/thinking.gif
    For me, I used a 4 hole plastic resin 1in. spacer to help increase my signal and performance at low end. I needed all the help I could get below 3000 RPM w/ the cam duration I have as well as keeping the carb cooler.
