Carb Spacers....Worth it?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBadBowTie, Jun 15, 2000.
  1. BigBadBowTie
    BigBadBowTie 1/2 ton status
    Apr 6, 2000
    160
    AZ
    Crusin thru my PAW catalog, noticed the 1" q-jet carb spacers. Is there any adavantage/disadvantage to running them?
    Rick
    86 K-5
    http://www.BigBadBowTie.ColoradoK5.com
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Well, they do lift the carb off the intake, thus allowing the carb to run cooler. Also, its advertised that the higher position of the carb creates a ramming effect of the fuel, and allows it to mix more thoroughly. I've got one on my Sub...it seems to have a little bit more power...but without a dyno, I dunno!
    ken
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Ken, did you put it in? If so any other changes you have to make,linkage and stuff???
    Or is it just unbolt and slide in, Oh just thought of one my choke is on the manafold so I would need a longer choke link, do the make em?
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  4. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Pretty much a slide in deal...with the exception of the choke problem that you mentioned. I have electric choke, so mine was a simple 10 minute job.
    ken
  5. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    I had one on my old '77 K5 in high school. It seemed to help, but only at the high RPMs. The down side was that it made it a real pain to start in the winter time. Don't know if it was just an individual problem to my K5, but I took it off because of that.
    Mud is just thick water, or is it that water is just thin mud?
  6. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I broke my choke rod trying to bend it one time and couldn't find a replacement, so i took a welding rod, striped all the junk off it and bent a new one, a little epoxy on the end to keep it in place, perfect. thats how i solved the choke problem.
    RaisedK5
    "Friends don't let friends drive Fords"
  7. Blazerbob
    Blazerbob 1/2 ton status
    214
    Western NY
    The spacer is used to make more power at higher RPM's by letting the fuel/air mix better and cooler. I had a 2 inch spacer on my 71 Monte that I drag raced. I was going to put it on the blazer but I don't need to wind up the motor that often.
    <font color=blue>Blazerbob</font color=blue>[​IMG]
  8. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
    A carb spacer will help your low end if it is a 4 hole spacer. If it is a single plane spacer (1 big hole) it will hurt low end and help high end power.
    Jeff427
    <font color=red>Mud Dog Off Road Club</font color=red>
    http://jeff427.coloradok5.com
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    I was told by a very reputable carb builder that a carb sapcer on a low RPM application wouldn't do anything. They are good for high RPMs.
    Mike [​IMG]
    1982 GMC Jimmy - <font color=green>Emmett</font color=green>
    http://emmett.coloradok5.com
