Carb swapp
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85blazer350, May 31, 2002.
  1. 85blazer350
    85blazer350 Registered Member
    Sep 5, 2001
    51
    Grande Prairie,Alberta,Canada
    Ive got an edelbrock 2101 performer manifold with an edelbrock edl-1405 carb.I picked up a holley 1850-2 carb (not sure if thats the right model but that was the number in it)I was wondering if I could swapp this in place of my old carb and what all would i need for the swapp.Would the holley or the performer be better i would have to rebuild the performer.
    Thanks for any help.
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Holley's are prone to blow out the power valve IF you back fire at any time! other than that holleys are ok. I run the Edelbrock carb on my rig and it seems to run just fine.But its still personal preferance as to what works best for you.
  3. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    I dont have much experience with Edelbrock carbs, but I do run Holley's and I like them. They're cheap to rebuild and trick out, and real easy to work with. Like was said they do have a tendency to blow the power valve out with 1 good backfire, but they have a kit that fixes this problem. Aside from Quadrajets the Holley's are my favorite carbs. It should be a bolt on and go deal, just make note of the fuel line size and all the vacuum lines.
  4. 85blazer350
    Sep 5, 2001
    51
    How can I check if the power valve is good or blown when the carb is off the truck.
  5. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    pull it ou n check the diaphram for cracks
  6. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
