carb to fi motor swap
Discussion in 'The Garage' started by chebywanna, Jul 21, 2003.
  1. chebywanna
    chebywanna 1/2 ton status
    Apr 20, 2003
    277
    streamwood, (chicago)
    its the frist time i ever swap out a motor, and have never seen it done, nor do i know anyone that has (im all alone in this world /forums/images/graemlins/tongue.gif) so here are my questions.
    #1 i pulled a complete motor out of a 98 camaro and want to stick it into my 77 k20, now what preassure fuel pump do i have to get and do i need anything else (regulator?) or would it be as simple as hooking up the lines and power for the pump.
    #2 im quite sure the original motor had a mechanical pump, haven't looked yeat but anyone know where i can find an electric fuel pump for my truck? /forums/images/graemlins/truck.gif
  2. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Do yourself a favor and pull the sending unit out of the tank, in the 98, and take all lines with it.
    You can get an aftermarket electric fuel pump from any parts store. I would get an original if it was me...
  3. LoggieStyle
    LoggieStyle Registered Member
    Jul 10, 2002
    78
    Tujunga, CA
    I'm doing the same kind of swap right now. Get everything back to the fuel pump if you can, I didn't and I am regretting it.
  4. chebywanna
    Apr 20, 2003
    277
    i thought about that but the fuel tanks are totally different in the two, i havnt measured the dept of them but i doubt its the same, or is it?
    as to the fuel lines, i was thinking of reusing the original truck lines and just "modifying" the ends to meet up with the motor and pump.
    loggie, did you set the motor in place yeat? im wondering if the motor mounts mech up.
  5. LoggieStyle
    Jul 10, 2002
    78
    Tujunga, CA
    Yes I have dropped the engine in and had no problems with the motor mounts, I haven't attached the exhaust manifolds yet so I don't know if there is going to be a clearance problem there but eyeballing it, it looks like it should fit fine. I am actually going from an old 350 to a 454 from a 99 suburban so I can't tell you for sure that you won't have any issues but since your new engine is probably the same size as your old one, I would doubt it.
    As for the fuel pump, I ordered an oem pump and it has a spring loaded collapseable base so depth wasn't an issue, perhaps the camaro pump is the same, you might want to check it out. I did have to widen the hole in the tank to fit the new pump, that was a pain but generally in-tank pumps are better.
    The fuel lines will probably be the least of your worries but I have had trouble because there aren't any good parts stores around me and the a-holes at autozone and kragen keep trying to sell me regular fuel hose when I ask for fuel injected hose. I think they want me to die or something.
    Anyhow I am doing the same kind of swap so I will try to answer any questions you post, but I am learning as I go along so please don't take anything I say as expert advice.
  6. rigdonhome
    rigdonhome 1/2 ton status
    May 11, 2003
    252
    HoosierLand
    The first thing to do is get the factory service manuals for the Camaro... You'll be pulling your hair out for the next 6 months without it. www.helminc.com
    Sal
  7. dyeager535
    26,980
    Fuel pumps out of '88 TPI Camaro's (and the like) are a "drop in" to replace the TBI fuel pump (in the correct 87-91 sending unit) for the '87-91 K5's.
