Carb to Injection Swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beefcake83, Jul 12, 2001.
  1. beefcake83
    beefcake83 1/2 ton status
    Jun 24, 2000
    240
    Alaska
    Hi all - I'm looking into how hard/ much cost to swap out my Carb for fuel injection. I've only owned my Jimmy for a year, and have had to adjust the choke 3 times with the changing seasons (Alaska). My wife is very for the swap if it will let my rig start right up with minimal cranking. Just checking to see what would be involved and if I could tackle it myself. Pros and cons to the swap are wanted. Would it change much of my emissions? Thanks, Gary
    Gary Graham
    '83 GMC Jimmy 350 'Beefcake'
    Eielson AFB, Alaska
    Metallica & Mountain Dew
    http://community.webshots.com/user/beefcake83
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Check out this site: http://www.howell-efi.com/complete_kits/mpi_tpi_index.html They offer complete kits for just the swap you want to perform.
    <A target="_blank" HREF=http://www.angelfire.com/super/ThunderTruck>http://www.angelfire.com/super/ThunderTruck</A>
  3. 88streetblaze
    88streetblaze 1/2 ton status
    Jun 27, 2001
    314
    middle of sticks, oklahoma
    and it also depends on wether you want throttle body injection or tuned port injection. tuned port takes a little more work but it has the injectors right over the vavles so it has more control over the effeciency of the engine but then you would have to get the entire intake while tbi can be put on almost any standard carbrator intake. i converted mine over to the tuned port ( i put a corvette lt 1 in it) from the throttle body and i love it.....
  4. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Went to TPI a while ago and love it. As long as you have the hardware, a good wiring harness, and some time it is an easy swap, really. Used a Painless Wiring harness, easy plug and play, new chip burnt for my motor combo, etc.
    If you do it, research it all the way............whether TPI or TBI, lots of good resources out there.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.alloffroad.com>http://www.blazzinor.alloffroad.com</A>
