carb to TBI swap, going to swap and need any info available
Discussion in 'The Garage' started by Okiemuddog, Apr 13, 2004.
  1. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Well, I am getting a smoking deal on a TBI set up and serpentine belt set up too. I am running a '91 model engine, so my heads will work. I want to make sure to get all the parts from the other truck. Here is the list I have so far
    Intake
    TBI
    ECM
    wiring harness
    all sensors
    distributor
    driver side manifold for O2 sensor
    all hoses and lines hooked to engine
    I am going to run a Howell TBI pump, so that covers the fuel delivery method. If you know of anything else I am missing please post up.
    I need all the information on this swap I can get, so any and all links would be helpful. I have searched and got a little info, but a lot of posts to look through.
    The serpentine set up, do I have to change all my accesories over to late model ones for this to work? I assume I will also have to change my power steering lines too.
    I am not trying to beat a dead horse, any info would help me.
    Thanks,
    Krennen /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  2. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Just e-mailed you ALL the wiring diagrams you could pssibly need for TBI systems /forums/images/graemlins/thumb.gif
  4. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Could you e-mail them to me also, thanks.
  5. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    You need to consider mounting an in-tank pump setup on that truck. The external pump might work alright for a while but they are problematic....
    Other than that, it's an easy swap!
    Andy
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    External pump is the way to go IMO. They sell many different kinds of them that will work with TBI.
    Check your catalog at work (you guys sell the same fuel pumps I do) There are at least a half dozen inline type pumps with different inlets that will work great in this application.
    If you want to go the easy route the painless harness is about $300. I haven't decided yet.
    I'm planning on running a 3 wire O2 sensor too because I'm going to have mine back in the headers a ways from the engine.
    For the serpentine yes you will need to change to the late model power steering pump and a CS style alternator. Well worth it IMO. I've got a setup on the floor waiting to go in my own truck.
    Good luck, take pictures, and tell us all how it went if you beat me to it as I'll be doing this swap probably this summer.
