Carb to TBI Swap-what mods do I need to do?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazin topless 75, Apr 28, 2004.
  1. blazin topless 75
    blazin topless 75 Registered Member
    Feb 5, 2004
    47
    Connecticut
    I am thinking about swapping out the carbuerated 400SB in my '75 for a 350 with TBI. I need to rebuild the 400. I have a TBI parts truck so availability of parts isn't a big issue. What are the mods that I will have to make? I am already planning to swap out the fuse block/wiring harness due to butchered wiring. I will also probably swap the TH350/NP203 for the 700R4 set up so that I can rebuild that as well.
  2. dyeager535
    26,982
    191
    I haven't really looked over the swap into a vehicle as older as yours, nor TBI in general, but swapping the ENTIRE harness out (cab, engine, etc) is a good idea IMO.
    Probably look into swapping the column and cluster as well, that way you don't have to hack up YOUR good harness.
  3. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    I just put TBI in my 72... you will need all high-pressure fuel lines or hard lines, a fuel return line, inline electric fuel pump, wiring harnesses, TBI, Computer will have to be recalibrated... thats all I can think of right off hand.
    Hope that at least helps getting you on the road to FI. /forums/images/graemlins/thumb.gif
