Carb tuning 101
Discussion in 'The Garage' started by 78Suburban, Apr 4, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I'm wanting to fine tune the Idle mix screws on my ebrock performer. I know I can back each one out till I see a small increase in RPMs, but I don't have a good tach that I can simply plug into the motor. Can I just use a vaccume guage and turn each screw untill I get the highest vaccume reading? What is a good vaccume number to look for?
    thanks,
    James
  2. jaredmajor
    jaredmajor Registered Member
    Mar 2, 2005
    96
    Anchorage, AK
    Yeah the vacuum gage is the other way to do it. Or by ear with the rpms. I have a tach, but i do it by ear. Vacuum readings, you just want the highest vacuum reading, this will all be dependant on what cam you are running, bigger cam lower vacuum at idle.
  3. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    is using vaccume a fairly precise way to do it? Should I turn them all the way in, then 2 1/2 turns out and start tuning from scratch, or should I simply try turning each screw in and then out and see what raises the vaccume? I know I need to do one at a time.
    thanks,
    James
  4. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    I use a vaccum gauge and it is dead on balls accurate. I recomend turning both screws 1/8th at a time. The goal is to achieve the highest vaccum.
  5. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    Definitely no more than 1/8th of a turn. One time a mechanic showed me on their fancy tailpipe machine the difference a minor turn on the mixture screw can make. I was surprised.
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
  7. norville
    norville 1/2 ton status
    Dec 27, 2005
    268
    A stones throw from Pargon Mountaintop Pa
    I'm pretty sure E-brock has a procedure for doing it. I thought it was 1 1/2 turns out and go from there.
    bob
  8. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    I agree with the 1 1/2 turns before you start tuning. A metering rod kit would help fine tune it even more. Also adjusting your accelerator pump to your personal needs could help too.
