"Carb won't idle down"
Discussion in 'The Garage' started by apache7, Sep 18, 2003.
  1. apache7
    apache7 Registered Member
    Sep 18, 2003
    12
    RI
    \"Carb won\'t idle down\"
    Who ever posted this problem should check to see if the throttle plates are hitting the gasket. Loosen the carb and make sure that the butterflies (throttle plates) are opening all the way, and also closing all the way.
  2. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    Re: \"Carb won\'t idle down\"
    Why did you answer a post with a new post???
  3. apache7
    Sep 18, 2003
    12
    RI
    This was posted in the 2nd generation forum. I can not post there yet, I did want to let the guy know a possible fix is all.Thought he might see it here.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    So why not register as a member?
  5. apache7
    Sep 18, 2003
    12
    RI
    Because I am at work at this time. Maybe at some point I will when I am home.
  6. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i'm not saying a word /forums/images/graemlins/smirk.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
