CARB????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Aug 18, 2001.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    Ok Winter is coming and I still need to either get a new carb or rebuild mine. I have the stock carb for my 85 Jimmy with a 305. Should I rebuild it or buy a brand new aftermarket carb for it Id like it o be reliable for the long winter ahead.
    1985 GMC JIMMY
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I went through 3 remanufactured carbs before I could get my Blazer to start fine in cold mornings (and I live in warm weather). It's an Edelbrock Q-jet #1902. I highly recommend it. Edelbrock has an application for different years if you need to stay legal.
    Rebuilding your carb will fix problems with old gaskets or bad adjustments, but deeper problems like bad vacuum canisters and worn shafts will remain there, giving you more headaches.
    <font color=purple>//////
    <a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  3. Ancient_4X4
    Ancient_4X4 Registered Member
    May 5, 2001
    35
    ND, USA
    I have an Edelbrocke 600cfm carb w/electronic choke. I'm not sure if it's the quadrajet version, but I love it. My 1977 chevy truck always will start on the first crank or two even when it's minus 60 outside. I have two springs on the carburator though so that it idles down easier.
  4. ironmikek5
    ironmikek5 1/2 ton status
    May 31, 2001
    145
    Massachusetts
    I'm rebuilding one of my Q-Jets right now, I'm hoping that I will have good news when finished. The Q-Jet is a good carb for off-roading, but if the rebuild doesn't cure my ills I'm going Holley.
    <font color=red>"Oil? That's not my oil...that was there before" </font color=red>[​IMG]
  5. dyeager535
    26,975
    Not going to get a better all around carb than a Quadrajet. Rebuild it correctly and you can't go wrong. If you are worried about it, have a carb shop check the drivers side of the primary shaft for slop, and have them bush it if necessary.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If you have the bucks I think you should get the aftermarket Q-jet carb from Edelbrock. Or a remanufactured one from JET<a target="_blank" href=http://www.jetchip.com/fuel/streetmaster800.cfm>http://www.jetchip.com/fuel/streetmaster800.cfm</a>
    They are both good carbs and its nice to have all new parts for reliability and the throttle shafts are rebushed..
  7. dyeager535
    26,975
    If the carb has not been sitting during it's life, almost no parts (that a "rebuild" kit won't replace) "wear out". The float is something I would likely replace, but everything else the rebuild kit would fix. Primary throttle shaft wear and corrosion from sitting are the Q-jets worst enemies. If it hasn't been sitting, corrosion can be pretty much ruled out.
    Dorian
  8. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    go for the Q-jet Edelbrock 1900s series. just put one on my 72, adjusted the idle screw and drove off. My last one(original) was rebuilt(by me, not an expert) like 2 times and could not get the darn thing working correctly. I figure it that one lasted 30yrs a new one should last as long.
    ARQ.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
