Carb?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kombi59, Jan 11, 2004.
  1. kombi59
    kombi59 1/2 ton status
    Nov 15, 2002
    197
    Anyone have any suggestions for carbs at angles? mine floods would an adjustable fuel pressure regulator help? maybe run low pressure for the steeps? thanks chad. /forums/images/graemlins/1zhelp.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    what kind of carburetor? im betting its a holley..
  3. kombi59
    Nov 15, 2002
    197
    edelbrock 650
  4. kombi59
    Nov 15, 2002
    197
    I've heard extending the vents will help also but how would you do that? with rubber hose?
  5. Confedneck
    Nov 1, 2002
    5,236
    edelbrock makes an offroad needle and seat package for their carbs.. its less than 20$ IIRC.. check out jegs.com
    that is supposed to help a lot..
    i run a holley pos right now and it does ok.. ill be going QUADRAJET though, they are pretty good for off camber, especially for a stock carb..
  6. kombi59
    Nov 15, 2002
    197
    thanks I'll try that /forums/images/graemlins/thumb.gif> /forums/images/graemlins/k5.gif
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    edelbrocks are not known to be great carbs for angle. You can add the offroad needles and seats and extend the vent tubes to help out, but from what I understand there design doesn't promote running at angles.
    The Holley Truck Avenger and the Qjet are the only 2 carbs I know of that run well at angle.
  8. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Ive got an edelbrock q-jet that Im selling, those are supposed to be good carbs for angles. its the 1910 model q-jet that flows 850 cfm, if you are interested PM me
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    quadrajet is the way to go /forums/images/graemlins/laugh.gif /forums/images/graemlins/thumb.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Edelbrocks suck for angles. See the badlands video if you don't believe me. Mine is horrible.
    The carb for angles is called TBI. It can be found cheaper than a new Q jet. It's some work to install it, but it's worth it.
  11. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have tryed to modify Edl /AFB carbs for off road. They will run better off road with the spring loaded seats dropping the float level and extention tubes. Even after modd them Every one I had always flooded out going up steep long hills.
    I have also modded Holleys for off road but I could never make them run as good as a properly tuned Q- Jet off road.
    Q-jet is the only carb I like for 4x4s. I even have put them on Fords
    The only thing better than a Q-jet is fuel injection.
