Carbed 350 in a 87' TBI
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by headcrash0101, Nov 12, 2003.
  1. headcrash0101
    headcrash0101 Registered Member
    Nov 4, 2003
    17
    Carbed 350 in a 87\' TBI
    I have an 87 with a locked up 350tbi. I have a strong running 350 w/ a holley carb. What changes have to be made to the wiring harness. Can I use the engine harness from the 78' 350. What about the cab harness. Should I swap that out too. The 350 TBI harness goes throught the firewall to the computer, where the carbed harnesses computer in picked up in the cab.
  2. dyeager535
    26,980
    Re: Carbed 350 in a 87\' TBI
    Or, just swap the TBI stuff to the new motor.
    The engine harness (starter, coil, etc.) is already seperate from the TBI harness as I understand it.
  3. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    You may want to check how the tbi intake bolts to the tbi motor, it may be diffrent then the old school ones.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sell me your TBI setup if you don't want it!!
  5. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    My friend and I converted his '88 Suburban from TBI to a carb. He just took all his old wiring (from the fuse box to the motor) and computer out, and we put a wiring harness from I think it was about an '80 or so in, and pretty much everything worked. I can't remember right now if we did anything else. I might be forgetting something important.
  6. dyeager535
    26,980
    Easy enough, swap the heads too.
  7. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    what about the fuel pump?
