Carbon canister question
Discussion in 'The Garage' started by Desert Rat, Jun 1, 2003.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I have a 74, so I don't need to smog it in Cali. However, I chucked the carbon canister since it was thrashed. Now I'm putting the Blazer back together and wonder if I need to replace it with a new one or if I can cap the line or what?
  2. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    All a carbon canister is is a trap for gas fumes. then when the motor has vacume (or in a newer car the solonoid opens) the motor draws the vapor that would normally evaporata and be lost and uses it to improve econimy and make the vehicle cleaner. So yeah you can just cap em but believe it or not over the long run you may notice a change in econimy /forums/images/graemlins/ooo.gif
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    mines disconnected right now. Put a new carb on and all my lines are still there but none of them are doing anything. All I noticed is my gas tank used to have a problem where when I took the cap off I could hear a vaccum like it wasn't breathing, without the lines hooked up thats gone. Something must have been wrong.
  4. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Sounds good. I guess I'll just run a hose off the metal line that goes back to the tank and cap it with a VW fuel filter like I use on my diff vent lines...
