Carbon coming out exhaust???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin Obsession, Jan 12, 2002.
  1. Blazin Obsession
    Blazin Obsession Registered Member
    Sep 25, 2001
    64
    B.C Canada
    I have carbon coming out my exhaust and my truck is running like sh*t, pulled #1 plug and it is covered with carbon. What is happening??? HELP!!!
    <a target="_blank" href=http://www.blazinobsession.com/>http://www.blazinobsession.com/</a>
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Your Profile says You got a holley system.
    What kind of Holley FI system is it ?
    If its a Pro-jection. Check for a leaky injector.
    If your FI system is one of the newer Comander closed systems check the O2 sensor.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze> Blazer pics</a>
    <font color=blue>Nevada... Where the pavement ends and the west begins
  3. Blazin Obsession
    Sep 25, 2001
    64
    B.C Canada
    It is a throttle body type, I will check the O2 sensor in a few minutes,, I just took the truck for a drive and it ran crappy and even backfired many times until it warmed up, then the idle went up to about 1800 rpm and did not come down.
  4. Blazin Obsession
    Sep 25, 2001
    64
    B.C Canada
    OK I removed the O2 sensor and cleaned it with brake cleaner, the Blazer seems to run a little better,,,,,But how can I test the sensor to be sure thats the problem? I don't want to buy one unless I have to.
    Ken
