Carbon Metallic Brake Pads
Discussion in 'The Garage' started by Smitty, Jun 18, 2004.
  1. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Is there any advantage/disadvantage to carbon metallic brake pads? Need to replace brake pads and shoes on a vehicle that does a bit of towing and would like to replace them with something that will give the best stopping power possible.
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Not real shure which ones the carbon metallics are but the more metal in the pad the longer they last but they are very hard on the rotors and make an annoying squeal. I hate mine! I am going to go with ceramic pads next time around.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    YES, they tend not to squeel, the can tollerate the highe temperatures and give better braking ability. Some people say they wear out the rotors faster, but i have never had any problems with this, I only use these pads on all my vehicles. /forums/images/graemlins/thumb.gif
    They will work good for a towing vehicle, just don't use the full on ceramic pads, those need to be at high temperature for optimal working performance.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Find out as much as you can about the particular brand and model before you install them. Some of the metallic pads work great when they're hot, but require a LOT more pedal pressure when cold. So that first stop at an intersection each morning could require more stopping distance than you're used to. /forums/images/graemlins/eek.gif
  5. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Never had that type of problem with the pads i have installed, i got mine at Autozone. Lifetime warranty, never have to buy another set. /forums/images/graemlins/thumb.gif They work great. /forums/images/graemlins/thumb.gif
  6. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    I think I'll put them on the wife's car first....
  7. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    I use nothing but the Bendix semi-metallics, and they've always been the shiznit for me. I can lock all four and skid the K5 and throw occupants through the windshield (or make indents in them the shape of the harnesses /forums/images/graemlins/smile.gif) so I say they work fine!
    -- A
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I only use name brand brake pads myself. I have Raybestos on my truck now, semi metallics for me.
    If your rotors are straight and you use shimmed pads you will not have squeeling.
    The post above about some pads requring heat to work is absolutely correct. We sell "fleet" pads at my work for this exact purpose, trucks that are under heavy load all the time.
  9. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    [/ QUOTE ]what you said, name brand only (quality problems with the no names) /forums/images/graemlins/waytogo.gif
  10. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    my brakes where squealing very very bad.so my dad took the sub to mechanic shop to fix the breaks the passanger side rotor was toast it had the metallic pads.
  11. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I have had very good luck with the Performance Friction Carbon Metallic pads. I run them on the Blazer, Firehawk, Elcamino and Motorhome. Seem to work very well when hot.
  12. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I have noticed that they don't Squeal as bad when they get hot.
  13. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I just bought a set of Performance Friction Carbon Metallic pads for my 1-Ton. Only because they where the cheapest set of Carbon Metallic pads I could find. I got them from Autozone for $40. All I can say is, "new brakes of any kind are better than old worn out brakes."
  14. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    very true. but after awhile when they start squealing real bad it will drive you crazy. I know it did to me I didn't want to drive the truck cause of that /forums/images/graemlins/doah.gif
  15. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    Were your pads from PFC?
  16. 88Silverado
    Mar 13, 2003
    2,664
    I have the z-rated pads on the Blazer and the ElCamino and the standard ones on the firehawk. The z-rated pads dont feel real good when they're cold. Kinda have to push pretty hard, but ill tell you, they come on pretty good when they get warm to hot. I have run my ELCamino thru some of the mountain canyons around here to where them brakes were smokin hot and they still worked good. Thats why I choose to put PF pads on the blazer and motorhome.
  17. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Raybestos "Super Stops" where my favorite brake pads, but I think Raybestos discontinued them in favor of "Pro Stops".
  18. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Napa Severe Duty and Napa Ceramic brakes. I have the SD on the the front and the Ceramics in the rear on the 14bff with disc. The D60 that is going in has the Ceramics too...I really like these pads...I have put them on a number of vehicles...both mine and my friends' and they are great. much less dust better stopping power when hot and they last much longer...
    Chris
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Napa's brakes are Raybestos aren't they?
    I will not use brake pads from any company but Wagner, Bendix, or Raybestos.
  20. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    United, which is the brake division of Dana, makes the Napa brakes...
    Only problem I have ever had with Napa brakes was a rotor that warped with in 10,000 miles but it was warrantied and all is still good
    Chris
