CARBS
Discussion in 'The Garage' started by CHEVY 4WD, Jul 28, 2002.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    What would be the Best off-road carb?(question asked for a SB some what modified)
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Quadrajet, with out a doubt.
  3. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    REALLY??? Like a stock? I though it would be to restrictive(SP)
  4. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    Yep, just a plain old stock quadrajet. You dont have the fuel bowl flooding and starving problems that are associated with carters and holly's. The new truck avenger is supposed to be better about killing the engine at big angles. My buddy is running a double pumper now and it has to be the worst carb I have ever seen for off roading. When he hit the steep hills it dies and floods the engine.
    As for the restriction issue, look at those secondaries, they are HUGE!!! /forums/images/icons/shocked.gif
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Q- jets for truck SBC engines will flow up to 800 CFM. I would hardly call that "Too restrictive". And they are the best carb made for off roading. They will also usually give better fuel economy than the other performance carbs.
  6. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    if q-jets are so good then why does everyone talk so bad about them and why do you need a adapter plate to run the with aftermarket intakes
  7. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I have Edlebrock Performer Intake and Edlebrock's 1901 Q-Jet and it doesn't require any adapter plate.
    I belive the plate is for simply converting an intake that wasn't designed for a Q-jet.
    Low RPM = OffRoading, Q-Jet rules!
    High RPM = Racing, Q-Jet sucks!
    There are more gearhead high RPM racers out there giving the Q-jet a bad name than there are Low RPM Off-Roaders giving it a good one! Make sence?
    Anyway good luck
    .02c /forums/images/icons/grin.gif
  8. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Definately a Q-Jet. Coming from the muscle car scene you'll hear a lot of bad mouthing of the Q-Jets because they are rather difficult for the novice to performance tune properly, can be difficult to get performance jets and don't have the aftermarket push. Hence the Carter, Edelbrock and Holley dominance in that arena. Additionally, the strip is fairly predictable with the terrain and directional forces you'll put on the carb so specialization in the newer carbs helps the strip application. I ran a Holley 850 double pumper on my truck originally and that had to be the worst experiences off road I've ever had, runs great on my muscle car though. Inclines and bumps would stall the engine, fuel economy was poor and the bottom end was not as predictable or useable compared to the stock Q-Jet which is back on now, getting 15 mpg on a 415ci and only stalls about the same time my locker isn't helping me any more on an incline. The only better route in my mind is EFI. If you never take your truck off road then maybe a Carter, Edelbrock or Holley would be a good choice (I liked my double pumpers power on the street) but off road, theres only one.
