Carb's
Discussion in 'Pacific Region' started by Muddytazz, Mar 15, 2004.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Carb\'s
    Who here local or even somewhat local to me is willing to swing by and give me a hand trying to figure out my carb problem? If anyone can, either respond here or pm me.
  2. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Re: Carb\'s
    Whqat kinda problem you having Jeff?
  3. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Re: Carb\'s
    You should have asked me when I was at your place a few weeks ago, I had 2 spare Quadrajets in the truck. /forums/images/graemlins/doah.gif
    What problems are you having?
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Re: Carb\'s
    Yeah man, what kind of prob's are you having? /forums/images/graemlins/ears.gif
  5. JDBlazer454
    JDBlazer454 1/2 ton status
    Feb 27, 2002
    951
    Vancouver, Wa
    Re: Carb\'s
    First off what kind of carb?
    Second what kind of problems?
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Carb\'s
    Quadrajet
    When you go to floor it, it coughs, sputters, runs really rough like its starving, let off the gas a little and it runs fine. Kinda vague description, but its the best I can do right now.
    And no shannon, its not the intake gasket, I did that trick you told me about and nothing happended.
  7. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    Re: Carb\'s
    accelerator pump may be shot. get a $20 rebuild kit and clean er up. the kit comes with a new accelerator pump.
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Carb\'s
    Kits do not come with new accelerator pumps anymore, only the plunger rubber piece and the spring under it. If you want a new accelerator pump, you have to buy that extra. Trust me I know, I just rebuilt this carb 8 months ago /forums/images/graemlins/angryfire.gif
  9. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    Re: Carb\'s
    the little plunger is the accellerator pump. when that rubber gasket at the bottom of it gets old and dry it stops working well. but if you rebuilt it 8 months ago, it should still be good. you can check it with the rig off by looking in carb and opening the throttle. you should see fuel squirt out the accl. pump jets forcefully. are you getting good vacuum? checked all the other stupid stuff like fuel filter, fuel pump, base timing?
  10. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Carb\'s
    Replaced the (in carb) filter at rebuild, don't have a timing light to check timing (but it idle, it seems good) fuel pump was my next thought.
  11. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Re: Carb\'s
    Well, if your confident in your carb rebuild abilites, and you don't have any vaccum leaks... /forums/images/graemlins/thinking.gif That sounds EXACTLY like what happened when my fuel pump went out. I wish I would have been able to figure it out then! I spent a chunk o' $$ before I FINALLY figured out it was the fuel pump! /forums/images/graemlins/angryfire.gif Anyway, I know my whole fuel delivery system is in perfect working order now! /forums/images/graemlins/tongue.gif /forums/images/graemlins/rotfl.gif
    A $20 fuel pump is a cheap fix.
  12. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    Re: Carb\'s
    True dat, yo! rule out all the simple sh!t. boarrow a timing light from someone too. just about every rig i've got has been off when i bought it. if that dist. hold down bolt has loosened over time she could have gotten out of wack on ya. keep us posted /forums/images/graemlins/thumb.gif
  13. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Carb\'s
    Will do on keeping you posted.
    What really throws me is the fact that this stumbling only happens on acceleration. Idles nice and cruises nice, just accel.
  14. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    Re: Carb\'s
    man, that sure sounds like an accel. pump problem to me.
  15. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Carb\'s
    Ok, here's another thing I've noticed that its done.
    Cruising down the road, start to go uphill, not more than 50 feet up the hill the burb starts stumbling without gas pedal change. I actually have to let off the gas to get it to stop stumbling. Now to me, this is more of a fuel delivery issue I would think.
  16. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Re: Carb\'s
    Sounds like the fuel pump. I did some preventitive maintainence, aka create a problem where none exists, and put a new fuel pump on. Turns out something was wrong with the fuel pump and my truck did exactly what you are describing. It would idle fine and drive ok, but once you floored it or hit a hill it would stumble and run like crap. Put the old fuel pump back on and no more problems.
  17. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Carb\'s
    Well it looks like i'm going to try the new fuel pump this weekend....will let everyone know how it turns out.
  18. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Carb\'s
    Ok, I got 1 problem fixed /forums/images/graemlins/grin.gif
    I finally changed the fuel pump and took out the in-carb filter and put in a in-line filter and my stumbling has so far gone away. I'll be hill testing soon though cause thats where it did it the most. But now I noticed on the way home from my dads where I did all this, the damn thing backfires like crazy.........and LOUD. Anybody have a timing light they want to loan me for a couple hours or just help me time it?
  19. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Re: Carb\'s
    Hmmmm... /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif Wanna do a partial work day this Sat.? I can borrow my buddy's timing gun, and you can bring your welder /forums/images/graemlins/deal.gif I'll be replacing my valve cover gaskets, plugs, & wires this weekend. Then I'll need to re-time my rig. I put in the HEI w/out replacing the plugs. When I pulled the #1 plug it looked pretty bad. Maybe even bad enough to throw my timing off a bit. /forums/images/graemlins/thinking.gif Better to be safe than sorry. Anyway lemme know what ya wanna do /forums/images/graemlins/waytogo.gif
  20. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Carb\'s
    I just got done doing the good ole timing by feel/ear bit. The ole burb has never run better than she does now /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
