carburetor vs. throttle body on crate motor
Discussion in '1973-1991 K5 | Suburban | Truck' started by GUMBY, Jun 7, 2001.
  1. GUMBY
    GUMBY Registered Member
    May 17, 2000
    35
    Alabama
    I have a dying 1988 350cid with a throttle body and 195K miles. I have been looking into crate motors from either GM or Jasper. I'm looking at either a stock replacement or a small step up to 300hp and 380lbs torque. I've heard conflicting ideas about my throttle body computer working on a crate motor that's not stock. Some say the stock computer will not handle the larger motor even if you change the chip because it's not made to handle the vacuum readings, etc. Others have told me that they have seen throttle body units work fine on larger engines and a chip change will work and if anything is affected, it's only the upper RPM ranges, 5K, that I'd not be using anyway. I want to keep my throttle body because of the problems carbs have on the trails. I don't want to put the extra money into a slightly larger engine if the throttle body isn't going to work. What do you guys think?
  2. lehtola
    lehtola 1/2 ton status
    Mar 21, 2001
    190
    North Carolina
    I've been researching pretty much the same thing. The key is knowing what your air to fuel ratio is. You can get a chip burned to deal with it but it might not be right the first time around. If you can provide whoever does the chip burn with the technical info on what you have they can pretty much determine what needs to be done. Try the following for chip burn info. The guys at these places are very familiar with manipulating what you need done.
    www.jagsthatrun.com
    www.turbocity.com
    www.fuelinjection.com
    www.tpis.com
    1990 GMC Jimmy 350/TH700R4/NP241/10 bolts, 4" skyjacker lift, 35x12.50R15 BFG All Terrains on 15x10 AR Baja's, Flowmasters.
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Ideally the stock 350 TBI unit itself probably won't quite be up to the task of 300 hp for air flow and injector concers... but you can swap on a 454 TBI or a Turbo city unit w/ larger injectors... and burn a new chip. Cam would be the major concern because of vacuum mostly, but for a 4x4 application you want torque. Overlap on the came also comes into play... I'd recomend one of Comp Cams or Crower's computer cams.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,385
    Georgetown, TX
    The computer reads the vacuum via the Manifold Absolute Pressure sensor. So any change to the cam or any other part of the engine can be compensated for via programming the chip. At least until you reach the limits of how much fuel the injectors can provide. Then you have to step up to larger injectors. You don't need the entire throttle body from a 454, those injectors will fit your existing throttle body.
    A chip that's properly programmed for your particular engine will make it run perfectly.
  5. GUMBY
    May 17, 2000
    35
    Alabama
    Thanks for the thoughts.
  6. cederic
    cederic Registered Member
    Apr 4, 2001
    31
    Nebraska
    Just food for thought... I'm buying a 330hp crate locally from GM (see http://www.paceparts.com/ for details) this site has all the specs and a cool picture of it.
    I'm putting it in my 85 to replace my totally tired 305.
    Mine was already de computerized when I bought it about 4 months ago. The guy that owned it before me put an Edelbrock intake and a Edelbrock EPS carb on it.
    I can't wait to get the 330hp under the hood, should be
    a fun ride...eh
    [image]http://www.animationcity.net/gifz/hand.gif[/image]
    What do you call a fly after you pull off it's wings ?
    A WALK...ahhehe
