Cargo and Side Panel Projekt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Nov 22, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    Going to gather materials soon and start building middle of next week...
    If anyone else has done anything like this speak up, links, pics anything you found was helpful, any tips or anything like that, spit it up.
    /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
  2. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    i did this for my k5:
    secret amp and storage space
  3. tecton
    Dec 1, 2002
    1,553
    WV
    did you buy the carpet pre-formed for your wheel wells?
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Not what you are looking for probably but I made my side panels out of a thin layer of fiberglass and then Herculined them. They turned out nice. Very lightweight and water proof. The sheetmetal will fall off the truck before they rought out. If you want some pics I can post a few up. They would suck for any kind of speaker box. I do have some electronics behind them though.
  5. tecton
    Dec 1, 2002
    1,553
    WV
    this is the biggest thing ive tried to make out of wood
    looks tricky to get the wood cut properly to fit over the wheel well
  6. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Depending on your intended usage, you might consider making that storage a "drawer" and not a flip-up style. If your camping/wheeling and have a lot of gear piled up back there, it would be a real pain to have to unload it all to gain access to those storage compartments.....
    /forums/images/graemlins/thinking.gif
  7. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    Take a large piece of cardboard and make a template. Makes it much easier to get the curves and angles just right. /forums/images/graemlins/thumb.gif
  8. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    That was another nice thing about using glass. I traced the shape of the original side panels that were all messed up onto 3/8" plywood. Added 1/4" or so all the way around. When it came time to fit them, I just took a grinder and knocked them down where they were to tight.
    passenger side.
    drivers side
    That is a 12 volt outlet in the rear of the driver side panel. Its kinda hard to tell from the pictures but I extended the panels in the front. They go all the way to the doors. The seat belt mounting helps retain the panel as well. The topper hold down trim peice also helps hold them on the top edge.
  9. tecton
    Dec 1, 2002
    1,553
    WV
    makes sense
  10. tecton
    Dec 1, 2002
    1,553
    WV
    im curious, how do the stock panels attatch to the bedside?
  11. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    just a few screws with some v shaped brackets
  12. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    maybe I'm missing something, but if the back is filled with camping gear or trail stuff, how is any setup easier to access? I suppose personal need is what matters in any situation.
    The carpet was preformed.
  13. tecton
    Dec 1, 2002
    1,553
    WV
    first off
    i havnt camped in about 8 years and intend to keep it that way...so lets get off that.
    Secondly, its for things i dont use often, tools, flashlights, spare parts, first aid, tow straps....ect
