carnage
Discussion in 'The Garage' started by surpip, Feb 4, 2006.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    so it seems my truck likes to eat the top bolts on the adapter, going into the tranny. When i got the truck they were both broke, anfter the rubicon trip(i guess thats what did it) they are both broke again
    is there a good fix for this? this time they broke, i had replaced the tranny mount, so i am not shure what is causing this to happen.
    any ideas?
    700r4 to np241
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    usually the threads strip before the bolt breaks. it shouldn't be twisting thats breaking them or all 4 would be broke. what grade bolt are you using? 8.8 or 10.8?
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i got them from the chevy dealer last time, so what ever is stock
    guess ill have to go with a higher grade this time
    always somthing
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    they are probably grade 8.8, equilent to a SAE grade 5. probably wouldn't hurt to try a 10.8 bolt.
    do you have the support brace that goes from the tcase to the bellhousing bolt?
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    yep shure do
    guess ill step up to the higher grade, im shure they wont be easy to find out here
  6. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Mine stripped once. I drilled out the holes and helicoiled all four holes, and haven't had a problem since. I think it is just a weak design. Thats a lot of weight hanging off the back with only threaded aluminum holding it on.
