Carnage!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Paxx, Mar 3, 2004.
  1. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    I blew out my rear driveshaft u-joint at the pinion side. I disconnected the rear shaft and drove it home in front wheel drive.
    It didn't make any funny noises on the way home but the pinion is sticking almost straight up yet the spring perches and everything else are lined up properly. Is it possible that the housing twisted on the shafts? what is the fix for this?
    This is my daily driver so I need to get this figured out as soon as possible. Thnx guys
    ~Max
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    yeah sounds like you rolled the pumpkin on the tubes, looks like a 12 bolt from your profile, the fix I guess find a way to turn it back down and weld the tubes back into the housing
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I had something similar happen to me. Housing is junk. Time to upgrade to a 14 bolt full floater.
  4. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    I was kinda thinking the same thing. Probably cost about the same too. /forums/images/graemlins/crazy.gif
  5. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    Oh yeah and it's only a 10 bolt.
  6. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    /forums/images/graemlins/thinking.gif If I just swap the rear end out for a 14 bolt will it work with my driveshaft or will it need to be modified to make it fit? I don't know the difference in pinion lengths.
  7. BowtieBlazer
    Jul 15, 2001
    2,462
    I believe the pinion length is slightly longer on a 14ff but not long enough to cause problems unless you have your differential customly rotated for some special app, in stock, I didnt have a problem nor %95 of the people on this board, the best part is if you can find a 14ff with brakes in good shape, you can tie them right in and go....
    Keep in mind though this means 8 lugs on the rear and 2 spares until you convert the front over.
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Pinion stickout between the 10, 12 and 14 bolts are all the same. No shorter or longer variation between any of them. /forums/images/graemlins/waytogo.gif
  9. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    you need to get a conversion u-joint for the shaft no biggy NAPA #447 I believe.... /forums/images/graemlins/thumb.gif
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]Keep in mind that there are spacers/adaptor that'll cure that problem.
  11. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    I think I am going to do a 3/4 ton swap. That way I get 4.10's and stronger all at once.
    I do have the money. That's not an issue. It's just that I was hoping to dump all the cash into the engine /forums/images/graemlins/whistling.gif
    /forums/images/graemlins/thinking.gif I guess it wouldn't make a whole lot of sense to dump it all into the engine though if the vehicle is already breaking apart around this one
  12. K5Kell
    K5Kell Guest
    my experience and measurments show that the 14 blt has a longer pinion. I needed to have my shaft cut when I did my 3/4 swap. just my 2 cehts though...
    -Kell-
  13. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,088
    487
    Grand Rapids area
    I found my 14bsf pinion to stick further forward than the 10b it replaced. I don't have the measurements with me, though. Just the increase in ring gear diameter would cause this, unless the bigger axles have shorter pinions.
