carpet padding
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by adamforsythe, Jun 5, 2006.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I am going to be replacing my carpet in my k5 some time this month. I have a bunch of padding that you would use under the carpet in your house. what kind of problems would i run into if I used that on my truck?
    Adam
  2. chalet2506
    chalet2506 1/2 ton status Premium Member
    May 9, 2006
    4,931
    Skeddadlin
    I'm not sure if house padding would stand up to the heat coming off your engine.I just put new vinyl in the floor of my 76' and put that radiant foil/bubble insulation down under the padding. It's inexpensive and easy to work with. You might want to put that down first.
  3. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Do you ever get the inside of your truck wet at all? Use automotive backing stands up to heat better doesn't absorb water as much. The foil stuff is good
  4. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    I would avoid house carpet padding in an auto if it will be near a heat source. It may have nasty fumes released if it gets hot. I'm not sure if passenger vehicle carpet pad has to pass FMVSS 302 for flame resistance. Residential carpet pad probably has nowhere near the safety requirements as automotive grade stuff. But I could be wrong, its happened before :) Anyway I don't think jute padding is very expensive.
  5. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Ok thanks I will buy some automotive padding for my floor.
    Adam
